Re: Do all 440s require a fan spacer ?
[Re: Texican]
#825186
10/08/10 09:10 PM
10/08/10 09:10 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
I have a 440 six pack and almost ready to install the engine. I have the original fan (2863 216) and a (new) fan clutch. Will my application require a fan spacer ? It seems like everything will work just fine like it is. Why do some cars have spacers and are they required/suggested ?
THanks for any advice.
There is no spacer with a clutch fan. The clutch takes the place of a spacer. A spacer is needed when you don't have a clutch and you would have a different fan blade.
[Re: RoadRunnerJD]
#825187
10/08/10 09:20 PM
10/08/10 09:20 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
There is no spacer with a clutch fan. The clutch takes the place of a spacer. A spacer is needed when you don't have a clutch.
The only 440+6 with a fan spacer would be a 3.23 geared automatic car. With a 22" radiator.
[Re: Morty426]
#825188
10/08/10 10:28 PM
10/08/10 10:28 PM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
or a Superbird
