Re: Thermostat with Electric water pump?
[Re: pleasantk]
#825178
10/08/10 07:01 PM
10/08/10 07:01 PM
Posts: 1,805 ky hills
thehemikid
ky hills
I have a CSI electric water pump on a mild 440 and was wondering if I should be running a thermostat? It is a street/strip car and runs a tad bit warm even on the highway (200ish). Just wondering if the thermostat would help. If it would help, which size would be best? Thanks in advance!
...Electrics don't flow a lot of water as is, so I don't think I would restrict it any. They are a constant flow rate and they dont speed up with the motor, except a little when above Idle (alternator output), & dont need restictions. I assume you have the 37gph CSI, there was a 30gph earlier that had 3 straight impeller's. ...The thermostat I feel makes the motor run at least that temperature rated by restriction/stopping flow to do so. ...Also "cooling" a motor has a lot of veriables & aint easy the way problems camouflage them selves. ...A tad over 200 aint to bad but, what Radiator, Fan, Shroud, will make a difference too. ...I have a CSI 37gph & never saw over 200 till I had my foot in it long enough producing a little more heat than the "flow rate" could handle. I dont use/need any fans till I'm in town or slow traffic.
[Re: pleasantk]
#825179
10/08/10 08:03 PM
10/08/10 08:03 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have a CV electric pump with a 180 stat and a HHR fan with a new aluminum rad from Mancini's.It runs about 200-210 after about 20 minutes on the highway(3000 RPM) but runs about 185-190 in traffic when running slow. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#825180
10/08/10 09:51 PM
10/08/10 09:51 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I ran a 160º stat with a Meziere electric water pump on the street. Car ran great on the highway, never went past 190º, even in the middle of the summer here in Florida. I suggest drilling a few 1/8" holes around the perimeter of the stat, to eliminate the possibility of collapsing the lower hose. Been there, done that.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: fourgearsavoy]
#825181
10/09/10 04:43 AM
10/09/10 04:43 AM
Posts: 4,231 State of retirement
52savoy
State of retirement
Anyone here was cooolant with additives? Suppposed to lower temps as much as 40 degrees...what do you think???? worth it?
you'll havr forgive for my sloopy writting. I Couldn't get to sleep so I just took an AMBIAN. Might fix soom breakfest....
[Re: 52savoy]
#825182
10/09/10 10:04 AM
10/09/10 10:04 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I just run cheap summit electric pump with a 160 thermastat champion 2 1" core radiator and a perma cool shroudless fan it gets max 190 after sitting in staging and doing a full pass. car normally runs 160-170. 12.5-1 compression idles all day at 180.
67' charger 499 RB
10.57 at 127
