Re: T&T at Napierville Dragway for Firefighter (Ron) & me
[Re: Kam*Kuda]
#824862
10/08/10 10:53 AM
10/08/10 10:53 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
The weather looks real good ! Sunny and a high of 50* with 10% chance of rain Get those pullies swapped and get that 9 second pass dude ! Hopefully those electrical gremlins are behind me. Ron
[Re: Dodgem]
#824868
10/10/10 10:44 AM
10/10/10 10:44 AM
firefighter3931
Ontario,Canada
Track was slick, couldn't hook at all....dang ! The short times were brutal.....in the 1.9 - 2.1 range. The stroker is just blowing the drag radials off despite a massive burnout. The MPH is up in the 123mph range but the ET's suck (mid 11's) Track prep was minimal but the big tire cars running slicks seemed to be hooking better than me. I guess it's tru that Drag Radials are marginal on poorly prepped tracks. It might be time for a set of stiff sidewall slicks. The green monster did good....a string of 10.00x passes and 135-136 mph but no 9 second slip.....ohhhhh so close ! Might head back out today and try again Ron
[Re: firefighter3931]
#824869
10/10/10 09:01 PM
10/10/10 09:01 PM
Posts: 14,509 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Ron, until you get the tire/chassis situation sorted out, you may want to try "walking it out" off the line a bit. even with less than 100% track conditions you should be able to get the short times into the 1.70's with a little driving finesse. i'm not saying it will be a "cure", but until you have it sorted out, you could try it a few times and see where it gets you. glad to hear you got the car up and running with the new mill!! whats the rpm at the finish line?
[Re: fast68plymouth]
#824870
10/10/10 09:09 PM
10/10/10 09:09 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I'm not so sure those tires like a massive burnout either. Tire pressure it quite critical as well....regardless, I'm sure your still having fun...we know the motor has tons of potential in it.
RIP Monte Smith
[Re: 69CHARGERMD]
#824872
10/10/10 09:43 PM
10/10/10 09:43 PM
fast68plymouth
So. Burlington, Vt.
Doug, i looked to see if he had posted anything from Bristol, but couldnt find anything.
1.55 is more like it.
#824873
10/11/10 05:23 PM
10/11/10 05:23 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Dwayne, this is a quote he posted on the Dodge Charger board,,,maybe he can confirm it,,, Good seeing you post Dwayne... !! Doug Quote:
(Run #2) i decided to run it hard and it launched well. The 60ft was in the 1.55 range and the pig was screaming. Unfortunately i had a brain fart and let off the throttle at the 1000 ft mark and ran an 11.01 @ 117 but the 1/8 mile ET was at 7.02 which shows high 10's in the 1/4
[Re: Labratt]
#824878
10/12/10 11:45 AM
10/12/10 11:45 AM
firefighter3931
Ontario,Canada
Thanks for the suggestions guys Spoke with Dwayne and he gave me some ideas and stuff to look at. Thanks Dwayne The trans was acting funny so i'll have the line pressure tested and make sure the pump is functioning properly. Going to run the valves and do a compression test. The car was low on fuel & with the stock (sumped) gas tank it's very possible the pickup was becoming uncovered. The guy in charge of refueling needs to be fired ! Everything is new in this build so it's going to take some time to sort through it. Plans are for another track day at the end of the month. Jim (Montessa) i will send you a message so we can hook up. I'd luv to see your car run Ron
