T&T at Napierville Dragway for Firefighter (Ron) & me #824860
10/08/10 09:11 AM
10/08/10 09:11 AM
Shannonville, Ont
Blown 68 R/T Offline OP
Shannonville, Ont
Were goin to Napierville saturday for some T&T to get Ron's awesome charger some 10 sec slips, and a couple 9 sec slips for myself, weather looks great, cars loaded and ready. Ron had some issues at Pinks but we'll sort them out and get that 572 haulin for him!
have a great Thanksgiving weekend everyone, lets get Turkey drunk
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: Blown 68 R/T] #824861
10/08/10 09:36 AM
10/08/10 09:36 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Have a blast. Try to leave the electrical gremlins at home
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: Kam*Kuda] #824862
10/08/10 10:53 AM
10/08/10 10:53 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
The weather looks real good ! Sunny and a high of 50* with 10% chance of rain
Get those pullies swapped and get that 9 second pass dude !
Hopefully those electrical gremlins are behind me.
Ron
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: firefighter3931] #824863
10/08/10 07:44 PM
10/08/10 07:44 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Play safe boys
Best of luck on your slips
End the season off on a high note
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: The Shadow] #824864
10/09/10 12:16 AM
10/09/10 12:16 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Kevin and Ron...Best of Luck on your 9 and 10 second time slips! Be safe!...but be fast doing it! Enjoy your Thanksgiving Holiday as well! Your buddy,Randy.
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: firefighter3931] #824865
10/09/10 01:14 AM
10/09/10 01:14 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
WOOOOOOO HOOOOO! Good Luck Boys! Go lay down some numbers!
-Kenny
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: StrokerAspen] #824866
10/09/10 02:26 PM
10/09/10 02:26 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: firefighter3931] #824867
10/09/10 03:03 PM
10/09/10 03:03 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'll be a Shannonville Sunday ONDR 1/8 mile looks good for air!
Good to meet you guys at pinks Bristol
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: Dodgem] #824868
10/10/10 10:44 AM
10/10/10 10:44 AM
Ontario,Canada
Ontario,Canada
Track was slick, couldn't hook at all....dang ! The short times were brutal.....in the 1.9 - 2.1 range. The stroker is just blowing the drag radials off despite a massive burnout. The MPH is up in the 123mph range but the ET's suck (mid 11's)
Track prep was minimal but the big tire cars running slicks seemed to be hooking better than me. I guess it's tru that Drag Radials are marginal on poorly prepped tracks. It might be time for a set of stiff sidewall slicks.
The green monster did good....a string of 10.00x passes and 135-136 mph but no 9 second slip.....ohhhhh so close !
Might head back out today and try again
Ron
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: firefighter3931] #824869
10/10/10 09:01 PM
10/10/10 09:01 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Ron,
until you get the tire/chassis situation sorted out, you may want to try "walking it out" off the line a bit.
even with less than 100% track conditions you should be able to get the short times into the 1.70's with a little driving finesse.
i'm not saying it will be a "cure", but until you have it sorted out, you could try it a few times and see where it gets you.
glad to hear you got the car up and running with the new mill!!
whats the rpm at the finish line?
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: fast68plymouth] #824870
10/10/10 09:09 PM
10/10/10 09:09 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I'm not so sure those tires like a massive burnout either. Tire pressure it quite critical as well....regardless, I'm sure your still having fun...we know the motor has tons of potential in it.
RIP Monte Smith
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: CompWedgeEngines] #824871
10/10/10 09:41 PM
10/10/10 09:41 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I think he got a 1.55 60' in Bristol.. ?
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: 69CHARGERMD] #824872
10/10/10 09:43 PM
10/10/10 09:43 PM
So. Burlington, Vt.
So. Burlington, Vt.
Doug, i looked to see if he had posted anything from Bristol, but couldnt find anything.
1.55 is more like it.
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: fast68plymouth] #824873
10/11/10 05:23 PM
10/11/10 05:23 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Dwayne,
this is a quote he posted on the Dodge Charger board,,,maybe he can confirm it,,,
Good seeing you post Dwayne... !!
Doug
(Run #2) i decided to run it hard and it launched well. The 60ft was in the 1.55 range and the pig was screaming. Unfortunately i had a brain fart and let off the throttle at the 1000 ft mark and ran an 11.01 @ 117 but the 1/8 mile ET was at 7.02 which shows high 10's in the 1/4
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: 69CHARGERMD] #824874
10/11/10 06:41 PM
10/11/10 06:41 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Sorry to hear you guys didn't get your slips.
Come to the osca event for a weekend before you buy slicks.
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: CompWedgeEngines] #824875
10/11/10 07:41 PM
10/11/10 07:41 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
M/T Drag Radials do NOT like long burnouts ,as mentioned. They are made for shorty 3-4 second blast. Anything longer, forget it for hooking. I am in the same boat. I "posed" with a long burnout for a camera , longer than 4 seconds. Killed my 60 foot. Next pass, short 2-3 second, back to my normal 1.60. Ron , congrats on the 10's.. We would have had some great races had you been at Norwalk. Good luck guys. Plenty of time still to get to your goals..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: firefighter3931] #824876
10/11/10 09:18 PM
10/11/10 09:18 PM
North Eastern New York State
montessa Offline
montessa  Offline
Ron, Sorry I missed you guys at the Ville. I was out of town for the weekend. The crew that I run with normally runs on Sundays. I know that time is running out for this year but, if you run again give me a yell so we can hookup!
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: montessa] #824877
10/11/10 10:22 PM
10/11/10 10:22 PM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Ron..I wish we weren't so darn far apart!!! You could borrow my new Goodyear stiff sidewall slicks for sure! Only 5 runs on them this year! Keep us posted next outing,Buddy!!! Randy
Re: T&T at Napierville Dragway for Firefighter (Ron) & me [Re: Labratt] #824878
10/12/10 11:45 AM
10/12/10 11:45 AM
Ontario,Canada
Ontario,Canada
Thanks for the suggestions guys
Spoke with Dwayne and he gave me some ideas and stuff to look at. Thanks Dwayne
The trans was acting funny so i'll have the line pressure tested and make sure the pump is functioning properly. Going to run the valves and do a compression test.
The car was low on fuel & with the stock (sumped) gas tank it's very possible the pickup was becoming uncovered. The guy in charge of refueling needs to be fired !
Everything is new in this build so it's going to take some time to sort through it. Plans are for another track day at the end of the month.
Jim (Montessa) i will send you a message so we can hook up. I'd luv to see your car run
Ron
