Re: '69 b body six way seat track questions?
[Re: Blue69Charger]
#824778
10/10/10 04:20 PM
10/10/10 04:20 PM
Posts: 584 San Jose, CA
Blue69Charger
San Jose, CA
BTT. What is the best way to re-install the counterbalance clock springs on the rear pivot? Would a spanner wrench work, what size do I need?
Edit: I ended up making a tool out of 3/16" x 3" x 3'L steel flat bar. I drilled and tapped the bar for four 1-1/2" 5/16"-18 bolts to capture the clock spring while I tightened it in place. Make sure you use grade 8 or stronger bolts.
