727 question #823871
10/06/10 11:42 PM
10/06/10 11:42 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
I have a 360 Duster with a 727 and Turbo Action reverse manual valvebody. The issue I am having is 3rd gear. First & second are great. When shifting into 3rd it won't always go into gear without playing with the throttle. Often when shifting into 3rd it acts like it pops into neutral. If it is in third and I let off the throttle and then accelerate, it also acts like it pops into neutral. Is the 2/3 band or clutches going bad?
Re: 727 question [Re: GKMOPAR] #823872
10/07/10 10:37 AM
10/07/10 10:37 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Could be
Have you checked your linkage adjustment latly?
Re: 727 question [Re: GKMOPAR] #823873
10/07/10 11:04 AM
10/07/10 11:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Clutches in the front drum , it's not actually going into neutral , if it is then your rear clucthes are going bad , when you slip thrid the trans is actually back into first gear , if you are making enough steam it might seem like you are in neutral.
no adjusting of the band is going to fix this , even if your linkage is out of adjustment and you correct it you have proably already smoked the clutches enough that it will not hold .
Re: 727 question [Re: JohnRR] #823874
10/07/10 09:31 PM
10/07/10 09:31 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Being a manual valve body the only linkage is the shifter linksge. It is adjusted correctly because as the transmission clicks into each gear it lines up with the shifter position. I know with this valve body when you coast in first it seems like it goes into neutral. That is the way it acts in third. I did try to adjust the band so I know that is correct. I am not a trans expert but it sounds like you are saying that when the trans is in third it is operating on the clutches in the front drum. So it sounds like those clutches are gone correct?
Re: 727 question [Re: GKMOPAR] #823875
10/07/10 09:46 PM
10/07/10 09:46 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
On a low idle ... how is it going-into reverse ?
Re: 727 question [Re: dOc !] #823876
10/07/10 10:15 PM
10/07/10 10:15 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Seems to be a slight delay again when shifting to reverse. When starting to back up there is a second where it acts like it is in neutral then in engauges and it is good after that.
Re: 727 question [Re: GKMOPAR] #823877
10/07/10 10:22 PM
10/07/10 10:22 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I would say it is badly worn or broken reaction shaft sealing rings ...or a blown-out rubber seal in the front clutch pack.
PULL the pan and report what is on the bottom.
Re: 727 question [Re: dOc !] #823878
10/07/10 11:40 PM
10/07/10 11:40 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Will do as soon as I have the opportunity. I will let you know. Thanks
Re: 727 question [Re: dOc !] #823879
10/08/10 08:44 PM
10/08/10 08:44 PM
Chesterfield, MIch
Cuda67 Offline
super street
Cuda67  Offline
super street
Chesterfield, MIch
I agree with the seal rings. It could also be the front drum is worn out along with the seal rings. Stop driving it. Maybe you haven't burned up the front clutch yet.
