Page 1 of 3 1 2 3
Numbers behind rear seat #822832
10/05/10 10:15 PM
10/05/10 10:15 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Do anyone of you guys know what the numbers behind the rear seat are relating to ?. Car is a 68 Coronet.
Re: Numbers behind rear seat [Re: 493RT] #822833
10/05/10 10:25 PM
10/05/10 10:25 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Could it be a date close to the assembly date if your car?
Re: Numbers behind rear seat [Re: RoadRunnerJD] #822834
10/05/10 10:32 PM
10/05/10 10:32 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Fender tag shows B22(Nov. 22nd).
Re: Numbers behind rear seat [Re: 493RT] #822835
10/05/10 11:06 PM
10/05/10 11:06 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
"G" St Louis plant by chance...?
Re: Numbers behind rear seat [Re: A12] #822836
10/05/10 11:13 PM
10/05/10 11:13 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
My '68 rr, it's a "G" St Louis built car......now let's all think; are there any options that may use any of those numbers as codes or are they an inspector's code?
Re: Numbers behind rear seat [Re: A12] #822837
10/05/10 11:21 PM
10/05/10 11:21 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
a few other members posted similar photos and I think they were "G" plant cars too. I saved the posted photos but can't find them at the moment.
Re: Numbers behind rear seat [Re: A12] #822838
10/06/10 12:00 AM
10/06/10 12:00 AM
New Berlin,Wi
Firepowerflyer Offline
New Berlin,Wi
My 69 gtx had numbers back there but now they got painted over,I'm goimg to look thru photos to see if I have any before it was painted.It was a St Louis car also.
Joe
Re: Numbers behind rear seat [Re: Firepowerflyer] #822839
10/06/10 12:13 AM
10/06/10 12:13 AM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
this one was over in the spring green post...
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: Numbers behind rear seat [Re: smac77] #822840
10/06/10 08:17 AM
10/06/10 08:17 AM
NC
6-789 Dart Offline
6-789 Dart  Offline
NC
we have a 65 Belvedere 2 with 6-6-6.
Re: Numbers behind rear seat [Re: 6-789 Dart] #822841
10/06/10 09:45 AM
10/06/10 09:45 AM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Could the "V" possibly stand for the vynil top?
Re: Numbers behind rear seat [Re: 493RT] #822842
10/06/10 12:22 PM
10/06/10 12:22 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
My 71 Challenger R/T has a large "5" behind the seat.
I assumed it was there to match up the rear valence as I recently purchased a rear valence that had number written on the inside on the same way.
Re: Numbers behind rear seat [Re: Morty426] #822843
10/06/10 03:25 PM
10/06/10 03:25 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I wonder if it is:
Roof Paint * Body Paint * Upper Door Frame Paint
Does anyone have fender tag info for the above pictured cars?
Re: Numbers behind rear seat [Re: 6bblgt] #822844
10/06/10 05:59 PM
10/06/10 05:59 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I wonder if it is:
My '68 rr (photo with 12 12 20) is FF1 mist green metallic with no vinyl roof (FF1 roof) and upper door paint is medium/dark green metallic. The dash is Catawba green a dark (flat/egg shell green) but not that close to the upper door green. The upper door green is close to '69 F8 green IMO. Here's my '68 rr with the 12 12 20. The SPD just FYI is April 2, 1968. I have the original fender tag BTW.
MikeR
Re: Numbers behind rear seat [Re: 6bblgt] #822845
10/06/10 06:01 PM
10/06/10 06:01 PM
Iowa - a member of the rustbel...
Birdturd Offline
Birdturd  Offline
I've posted on this also
Re: Numbers behind rear seat [Re: Birdturd] #822846
10/06/10 06:25 PM
10/06/10 06:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Wonder why the frist two numbers repeat?
8 8
12 12
14 14
Re: Numbers behind rear seat [Re: A12] #822847
10/06/10 11:09 PM
10/06/10 11:09 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
my guess they would be a vendor id
and maybe a date code of sorts
i'm sure all the body panels
were not stamped at the same place
and came from differant sources..
Re: Numbers behind rear seat [Re: A12] #822848
10/07/10 08:24 PM
10/07/10 08:24 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
8 8
12 12
14 14
Upper/lower body color/upper door panel color
Found this in a B5 blue '76 Aspen SE with a blue interior:
Re: Numbers behind rear seat [Re: In_The_Pink] #822849
10/07/10 08:35 PM
10/07/10 08:35 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
8 8
12 12
14 14
is that, is that B5 B5 ?? Why, why, the the double double ??
Re: Numbers behind rear seat [Re: 6bblgt] #822850
10/09/10 10:06 AM
10/09/10 10:06 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
1970 Coronet reference
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
1970 Coronet reference [Re: MMC Detroit] #822851
10/09/10 10:07 AM
10/09/10 10:07 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Fender tag
Page 1 of 3 1 2 3
