Page 3 of 6 1 2 3 4 5 6
Re: Pros and Cons for 284/484 cam [Re: 451Mopar] #82280
07/02/08 04:37 PM
07/02/08 04:37 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I have been looking at the hydraulic roller cams because of the oil quality problem, but the price of the lifters is pretty steep. I think cam and lifters cost close to $1,000!
I went with a Comp Cams 480 lift hydraulic roller in my motorhome, I used a 1991 long block and I was lucky a buddy who worked at a local Chrysler dealership heard they were throwing out old stock of hydraulic lifter in the service area. He went to go get them for me and it was too late. They were gone.
He dove into their dumpster and retreived them, they now reside in the engine of a 360 motorhome!
I paid 400ish for the cam, so all was good!
CrAzYMoPaRGuY
Re: Pros and Cons for 284/484 cam [Re: CrAzYMoPaRGuY] #82281
07/02/08 05:31 PM
07/02/08 05:31 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just to add more what-ifs....
I did a quick computer simulation using the Dynomation5 protools sim. using a very mild near stock 440 specs (with manifolds) and a theoretical 284/0.484 cam with 108 LSA installed at 108.
Peak Power was 412@5500 RPM, and torque was 494@3500 RPM.
Then I just widened the LSA to 110, and slightly shortened the intake duration, same lift and install position and got:
Power 416@5000 RPM, and 509 ft/lbs @ 3,000 RPM.
The interesting part is the difference in low end torque:
RPM 284 cam 275 cam Difference
1000 248 278 +30
1500 366 390 +24
2000 445 463 +18
2500 480 498 +18
3000 493 509 +16
3500 494 507 +13
I know it's just a lame simulation, but I am trying to show how the power curves differ, and how the newer cams are tring to get the same or better peak power while enhancing the low end power. This dosent even address the differences in ramp rates and the greater lifts the new cams have. On the other hand the newer style cams are harder on the valve train.
Then I made one change to the sim models, added headers with open exhaust.
Peak HP = 478@5500, TQ = 541@4000 (284 cam)
Peak HP = 476@5500, TQ = 552@3500 (275 cam)
The samller cams torque advantage was still there, just not as big a difference, and with the better exhaust the 284 cam made slightly more peak power.
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #82282
07/02/08 08:22 PM
07/02/08 08:22 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Which 284 484 cam...
There is original 0235 and the later one 07697. The later one is much more streetable with less overlap. We have run the 0235 in a couple of different engines with good sucess, its downside is low vacuum so if one has power brakes...
Check it out..
I'll have to check the receipts to see which one. I do know it was bought in the mid eighties though, so it's an old one.
Purchased 10/12/1988, part number P4120235.
Re: Pros and Cons for 284/484 cam [Re: VITC_GTX] #82283
07/02/08 10:22 PM
07/02/08 10:22 PM
its a good cam. 9+:1 cr/ at least a 2500 stall/ 3.55s are ok, 3.91s would be better.
i ran a 509 in a 440 with stock stall and 4.56s. worked great.
Re: Pros and Cons for 284/484 cam #82284
07/02/08 10:41 PM
07/02/08 10:41 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
for a street car, If you want to keep your stock converter and have a lot better idle-5000 RPM performance, I'd look at the 226@.050 duration lunati voodoo cam.
2017 Grand Cherokee Overland
Re: Pros and Cons for 284/484 cam [Re: patrick] #82285
07/02/08 10:48 PM
07/02/08 10:48 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
284/484 cam is a real good performer.Keep the cam and get a converter.
I've run 11.59 with that cam in my 383 Demon.
Nautilus Racing-
Re: Pros and Cons for 284/484 cam [Re: Chris2581] #82286
07/02/08 11:14 PM
07/02/08 11:14 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I ran one in My 82 Cordoba.
MP 360 short block
1976 360 heads-gasket matched with 1.88 intake 1.6 exhaust valves
X-celerator single plane intake
904 with 3500 stall conv
4.10 gears
The car weighed 3600 lbs completely stripped and I ran a best 12.71 @106mph That was with the power steering still hooked up.
Put that motor in an A-body and put bigger intake valves in it an it would be much quicker. I loved the idle by the way.
Re: Pros and Cons for 284/484 cam [Re: burdar] #82287
07/02/08 11:15 PM
07/02/08 11:15 PM
Anyone run a .484 with a 4-speed?
Re: Pros and Cons for 284/484 cam #82288
07/02/08 11:45 PM
07/02/08 11:45 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Yep..
One should have at least a 3.55 rear end, we ran it with a 3.91.
Just my ..
Re: Pros and Cons for 284/484 cam #82289
07/02/08 11:50 PM
07/02/08 11:50 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
wow, what a lot of dif opinions about this cam and overall all MP stuff.
after this I'm pretty sure won't ask anything else about cams and will stick with the one I did choose for the setup I will build soon with 280/474 MP cam.
KB240 pistons
ported 452 heads
stock everything else
166K MP converter
3.55 SG on 27" wheels
and everythiung to run with A/C
THEN after this first experience, will play LAAATER with some other cams. But definitelly everything has to do with what you likes or wish to feel driving your car. Nobody will be able to sit on your own place when getting build a setup!
Re: Pros and Cons for 284/484 cam [Re: Paul_Fancsali] #82290
07/03/08 12:04 AM
07/03/08 12:04 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
... The 292 and 284 are lucky to get 8-10mpg on a good day.
I've gotten 13.5-14.1 on the highway, at 70mph (with a spirited sprint or two even). 3.54 Dana, 440 4spd, .484 cam in a 71 Charger R/T. Also pulls right aroun 9-10" of vacuum at idle. May actually be a bit better than that now, as the last dyno run, we advanced the timing a few degrees.
As mentioned, throw as much timing at it as it will take. My initial is currently at 18º, which puts my total right around 39-40º.
Re: Pros and Cons for 284/484 cam [Re: Sinitro] #82291
07/03/08 12:06 AM
07/03/08 12:06 AM
Yep..
Just my ..
I'm probably going to run either 3.91 or 4.10's.
Re: Pros and Cons for 284/484 cam [Re: 440trk] #82292
07/03/08 12:54 AM
07/03/08 12:54 AM
same. got as high as 16mpg with a 440 4-speed. so for those who say this is a "race only" or "bracket cam"....
NOT
Re: Pros and Cons for 284/484 cam #82293
07/03/08 01:38 AM
07/03/08 01:38 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
NOT
I laugh at those who say that the .484 idles rough. I had the resto cam in my GTX and a guy I know with the .484 who has a Satellites car didnt idle much rougher. Another buddy just went from the .484 to the .509, didnt think the car idled rough before and it still doesnt. Im not one who picks a cam based on sound but im not very impressed with the lope of those two cams in a 440.
Re: Pros and Cons for 284/484 cam [Re: GTX MATT] #82294
07/03/08 03:08 AM
07/03/08 03:08 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Speaking of the Mopar Performance Cams, has anyone ever profiled the lobes for comparison.
I would like to see the actual duration numbers measured at least at these tappet lift points:
0.006", 0.020", 0.050", 0.100", 0.200".
Does the 284/0.484" cam actually measure 241 duration @ 0.050" like the catalog claims?
Also, Mopar lists the appliaction for the 284/0.484", 108 LSA as "Drag Mod. Comp", and even designed a 114 LSA version of the cam with the application notes "Revised centerline for improved drivability."
OK, I give up. If you insist the the 284/0.484 108 LSA cam is the best cam, Then I'm wrong, along with Mopar for re-designing their cam, and the other cam manufacutrers are wrong for creating the Hughes Engines cams, or the Laniti(sp) Voodo cams, or the Comp X-tream cams or the Crower Compu-pro cams.
Re: Pros and Cons for 284/484 cam [Re: Mr.Yuck] #82295
07/03/08 08:23 AM
07/03/08 08:23 AM
rochester,new york
P
plumebody Offline
plumebody  Offline
P
rochester,new york
11.80's with a weak 750 Eddy carb and a so-so trans. Bottom ends aren't as critical as heads, converter, and gear.
They are good cams for what they were designed for. Bracket racing. and the 73 440 was out of a Police Fury origanlly. Guy was going to put it in a Duster and ran out of $$. All he did was have a valve job, t-chain, 509 cam and used some old Offy intake w/ the T-quad. Car ran great on the highway.
You failed to mention that this time was with a procharger with I think 5-7psi of boost??
Re: Pros and Cons for 284/484 cam [Re: 451Mopar] #82296
07/03/08 08:40 AM
07/03/08 08:40 AM
when your in THE GAME long enough.. one tends not to believe what MoPar has to say.
Re: Pros and Cons for 284/484 cam [Re: 440trk] #82297
07/03/08 09:18 AM
07/03/08 09:18 AM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
I too have the 108cl 284/484 cam in a built 383.(12.5 trw's w/ported 906's,RPM intake,1 7/8 headers,PTC 3000 converter) I've been trying to get it to run better for the past couple summers and have only been able to pull around 9-10in of vacummn at idle (6-7 in gear)and still have terrible power brakes! I think some of the problem's is in the carb but one major inprovement's came from yanking one of the dizzy springs out completly! Atleast now its a million times more responsive than it was. I have no idea were the timing is at, I've been retarding it more and more and it actully runs stronger and stronger! Bottom end is better than it was too! I know I need more gear as its only got the 3.54's in it.
I think next Im going to step up to a 850dp holley and try that instead of the 750 vacummn sec. one on there.
I plan to keep tuning on it over the summer.
Over-all its not a bad cam to run............but there's got to be better one's.
Re: Pros and Cons for 284/484 cam #82298
07/03/08 09:19 AM
07/03/08 09:19 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Yep..
Just my ..
Run a 509 w/ a 4 speed and 4.10's and you'll be close to 11's. 484's and 509's have the same "drivability" so you might as well use the big bump stick.
Re: Pros and Cons for 284/484 cam [Re: plumebody] #82299
07/03/08 09:24 AM
07/03/08 09:24 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
nope that was a completely different car. The 68 dart ran 11's the 69 Charger was a car I had back in 91. The 67 coronet had the paxton. when I got the car it had a basic 9:1ish 440 w/ logs 484 cam and 3.55's. The car ran ok but really didn't have any bottom end (wrong cam) so I started by swapping in the Sumitt 488 cam. Ran much better and then things evloved to the supercharger. AND the 484 isn't such a great cam for a S/C car.
484's and 509's can run well but there are much better and cheaper cams if you want to use your stockish converter and 3.55's
