Is this the right distributor for a 71 440-6 4 speed #822743
10/05/10 09:49 PM
10/05/10 09:49 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
cuda?
Re: Is this the right distributor for a 71 440-6 4 speed [Re: domingo] #822744
10/05/10 09:52 PM
10/05/10 09:52 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
NO!
looks like late-'50s piece
Re: Is this the right distributor for a 71 440-6 4 speed [Re: 6bblgt] #822745
10/05/10 10:02 PM
10/05/10 10:02 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
or from a Marine Or Industrial application
Re: Is this the right distributor for a 71 440-6 4 speed [Re: domingo] #822746
10/05/10 10:10 PM
10/05/10 10:10 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
>Yes, I was having a hard time trying to ID it...it came along with the car...
Re: Is this the right distributor for a 71 440-6 4 speed [Re: domingo] #822747
10/05/10 10:27 PM
10/05/10 10:27 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
What you need will look just like this but will have a different vacuum advance unit
Re: Is this the right distributor for a 71 440-6 4 speed [Re: ScottSmith_Harms] #822748
10/05/10 10:35 PM
10/05/10 10:35 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
for a 71440 6bbl is 3438577
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: Is this the right distributor for a 71 440-6 4 speed [Re: 440beep] #822749
10/05/10 11:11 PM
10/05/10 11:11 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Man, I have a feeling that will be spendy....
Re: Is this the right distributor for a 71 440-6 4 speed [Re: 440beep] #822750
10/05/10 11:26 PM
10/05/10 11:26 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
here's mine - Joe
Re: Is this the right distributor for a 71 440-6 4 speed [Re: shakerjoe] #822751
10/05/10 11:30 PM
10/05/10 11:30 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
other side
Re: Is this the right distributor for a 71 440-6 4 speed [Re: domingo] #822752
10/05/10 11:39 PM
10/05/10 11:39 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Domingo from what I could find that might be an early or mid-50's distributor, read one post that referenced an early Hemi application it was a dual point.....
http://www430.pair.com/p15d24/mopar_forum/archive/index.php/t-7846.html
MikeR
Re: Is this the right distributor for a 71 440-6 4 speed [Re: A12] #822753
10/06/10 12:10 AM
10/06/10 12:10 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yep the one Joe posted is the one you need. I may have an NOS vacuum advance unit around here somewhere. To save buying an original you could have a fake carb tag made and build one out of any RB dual point point distributor with the right configuration to match the one you need.
Re: Is this the right distributor for a 71 440-6 4 speed [Re: ScottSmith_Harms] #822754
10/06/10 12:27 PM
10/06/10 12:27 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yep that's the way to go. The vacuum advances are still easy to find NOS
Re: Is this the right distributor for a 71 440-6 4 speed [Re: Morty426] #822755
10/06/10 01:27 PM
10/06/10 01:27 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Sounds good. Thats what I will do then! Thanks for all the pics and info.
