power steering getting to hot 250 degree
#822696
10/05/10 08:32 PM
10/05/10 08:32 PM
Posts: 163 Haymarket, VA
MOPARLZ
Haymarket, VA
I got a 68 charger with a 440 and headers and the power steering is geting to hot. I took the cooler off to see just how how hot it would get and it burnt my fingers when I tried to take the metal top off. 250 degree's. Any idea's as to to why??? There is a new steering box installed by the guy I bought it from.
Re: power steering getting to hot 250 degree
[Re: MOPARLZ]
#822697
10/06/10 12:00 AM
10/06/10 12:00 AM
RapidRobert
I wonder if there's a prob w the box that is making the pump have to develop max psi all the time or way more than normal & that is in turn causing the pump to overwork/heat up the fluid.
[Re: MOPARLZ]
#822701
10/06/10 04:33 PM
10/06/10 04:33 PM
Posts: 2,332 Addison Twp, Mi.
RobG
Addison Twp, Mi.
The blockage/debris is in the steering gear unit. I went through this this past summer.
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
[Re: RapidRobert]
#822707
10/08/10 07:50 PM
10/08/10 07:50 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
it will be messy, but you should be able to disconnect the return line (plugging the reservoir so it doesnt leak) and see how much fluid is actually returning to the pump. have someone turn the wheel, lock to lock, and see what happens at the return hose. make sure you wear goggles, and have a bucket to catch the fluid in. you'll know right away, if it's the gearbox. you might also open the feed line, and see that it is pumping enough fluid as well, if the return seems weak. at least you'll know, where in the system the problem is. i kinda feel, the cooler is on the pump, for a reason myself. removing it will affect the temp.
