I've been upgrading my 70 Coronet (originally 10" power drums) to a disc setup. I've got the 73 A body spindles, 10.87" discs with slider calipers, and the 1 1/32" aluminum master using the correct adapter. Braking is pretty good, but I can't really get any wheels to lock up. I don't have the prop valve installed yet. Brakes are properly bled. I'm thinking now its the single diaphragm drum booster causing the weak braking.
What are my options for a dual diaphragm booster? I'm looking for direct bolt-on as correct appearance is not important.
I think the '69 Charger disc/drum Bendix booster (Cardone or NAPA 54-73603)would work, but I am seeing if there are any other options. Maybe a direct bolt-on that accepts the 2 bolt master and doesn't need the 2 to 4 adapter? What are my other disc brake booster options?
