Re: alterkation front suspension
[Re: Jim_Lusk]
#822229
10/05/10 11:49 AM
10/05/10 11:49 AM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
I have one, but it is not in the car yet. It is a very nice setup.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
Post deleted by moparts
[Re: cudaboone]
#822230
10/05/10 12:20 PM
10/05/10 12:20 PM
[Re: abodyjoe]
#822233
10/05/10 01:48 PM
10/05/10 01:48 PM
Posts: 1,414 Stow ,Ohio
demon440
Stow ,Ohio
I have one in my Demon. The car is not done yet but quality and customer service are great.
[Re: Dragula]
#822237
10/05/10 03:40 PM
10/05/10 03:40 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Looks like you still have to run a notched oil pan. Same thing on my MF unit, the front of the pan has to be notched to clear. Wish I could run a full dragster pan...
Charlie's makes a pan that is notched for these. I just notched a standard Moroso 7 qt pan for mine. Little bit if time to do, but not much. A lot cheaper than the Charlie's pan.
[Re: blowndart]
#822238
10/05/10 04:42 PM
10/05/10 04:42 PM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
As others have said - Top notch well engineered solution that simply cant be beat. Period.
I know of only 1 minor issue with them that wont affect 99.99% of the people out there - so im not gonna bring it up. (Has to do with how I'm applying it - not an engineering problem at all). I already have a fix.
GO FOR IT - you'll be glad you did!
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
[Re: 71rm23]
#822240
10/05/10 05:07 PM
10/05/10 05:07 PM
Posts: 5,337 the house on the left.
cogen80
On the same subject, sort of. Does this setup accomodate for virtually any engine setup? Big block or 5.7,6.1? I'm gonna call but wondering for those who has put on in.
yes but you have to tell them what motor your running because the mounts on the frame are different for the hemi
[Re: cogen80]
#822241
10/05/10 06:49 PM
10/05/10 06:49 PM
G_T
Texas, Dallas
Or in my case (V10), you can specify no mounts and fab your own.
2012 Charger SRT8
[Re: cogen80]
#822243
10/07/10 09:22 AM
10/07/10 09:22 AM
Posts: 2,826 NY usa
540challenger
NY usa
Correct
Small/big block use the same k- frame and mount points
2 gen hemi is it own
and 3 gen hemi is another.
Bill uses poly spool type motor mounts too
[Re: 540challenger]
#822244
10/10/10 09:41 AM
10/10/10 09:41 AM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
If you put a "car" 5.7 in a B Body with an Alterktion, TTI cannot make a header that will fit around the starter...if you use the w5a580 transmission as well. The starter gets in the way. here is a pic of mine in my 70 GTX, not done yet so I can't comment on the ride, however, I have read many threads about this and EVERYONE who has done it , loves it. It was a piece of cake to install.
Driving modern convenience in classic beauty
