heads for a 416 #82203
06/30/08 06:18 PM
06/30/08 06:18 PM
72greencuda Offline OP
I have my 416 stroker bottom assembly 9.5 to 1 dish pistons at 65cc and I already have a set of J heads small valves 72cc brings my combo to 9.1 to 1 compression. These Js are they to small? , I have a set of magnums also id#5300 6671 was wondering if the magnums would be a better route for my car? 72 Cuda w/727 3000 stall Street car and I have an ld340 already w/a demonsizzler thermoquad.What should i do.Are there any problems running these magnums on my 71 340 block? Thanks Any help appreciated
Re: heads for a 416 [Re: 72greencuda] #82204
06/30/08 10:24 PM
06/30/08 10:24 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You have to convert to push rod oiling but other then that they are a good choice because of the closed chamber design. With a magnum head you can run more compression and be resistant to detonation. It would be best to get them ported to feed the extra cubic inches.
Re: heads for a 416 [Re: 69Cuda340S] #82205
06/30/08 11:57 PM
06/30/08 11:57 PM
Push rod oiling
Re: heads for a 416 [Re: 72greencuda] #82206
07/01/08 06:58 AM
07/01/08 06:58 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The old LA heads oil the top end through passages in the block/heads where as magnum heads oil the top end through the push rods. You can read more about the conversion to magnum heads here:
http://www.moparts.org/Tech/Archive/smallblock/7.html
