so i picked up another mopar! #821972
10/04/10 11:16 PM
10/04/10 11:16 PM
Detroit,Michigan USA!
E
erick72 Offline OP
erick72  Offline OP
E
Bought a 78 new yorker for 600 bucks. 43,000 miles! old lady car. anyways when ill get pics ill post them
But i have a few questions
1.The car has the lean burn crap on it. and im getting this weird gargling/boiling sound coming from the carb.its a carter i believe.what could that sound be?i tuned it and its a little better still kinda bad though.
2.The hood wont stay latched if i hit a hard enough bump it will pop up and be on the safety latch.what could i do to fix that?
3. What easy and quick improvments to do to make it get up and go with just taking crap off?like maybe the lean burn or if it has cats or not.
4. Also it has the flip covers for the headlights. Everytime i turn them on and they open i get a very annoying buzzing sound that buzzes, stops, buzzes click right at the relay under the dash. got another really from the junkyard still making the noise.So i unplugged them and it stopped.any idea what that could be?
thanks guys!pics asap when it stops raining!
Re: so i picked up another mopar! [Re: erick72] #821973
10/05/10 02:42 PM
10/05/10 02:42 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I'll take #2 for $200 Alex!
Either the "receiver" portion of the latch simply needs to be adjusted up a tad or it needs replaced. Maybe this'll bump you up and someone can help you with your other questions...
Re: so i picked up another mopar! [Re: erick72] #821974
10/05/10 03:28 PM
10/05/10 03:28 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You can swap out the lean burn for a typical Mopar ECU. You also have to change the distributor. That will give you a little timing to work with.
Remember that those cars had highway gears and 230 horsepower. Top that with the 5,300 lb curb weight and you've got issues with acceleration.
0-60 in 12 seconds. Quarter mile times were mid 17s.
Take a look here for a little info on them:
http://imperialclub.com/Yr/1978/index.htm
I like those cars. The red interior looks a bit like a bordello but they're comfy cruisers with a bit of class behind them.
- Stu Harmon
Re: so i picked up another mopar! [Re: erick72] #821975
10/05/10 03:39 PM
10/05/10 03:39 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
The 78 was the worst 440 ever built trying to meet the smog standards. It ran the poorest and generated the most heat. The carburetor has a phenolic base trying to prevent heat soak into the carburetor. What you are hearing is the the gas percolating. Also could be the water in the heads boiling and being trasmitted through the intake manifold plenums. You'll also see insulation under the valley pan that was stock from the factory. If it's not there, then that adds to the heat problem
The mechanism that the hood release cable goes to is not fully going into the locked position as the the hood comes down. It's a high corrosion area. Lube the heck out of and make sure the cable is moving freely along it's entire travel length.
Edelbrock Performer carb & intake manifold, and 2 1/2" dual exhausts. Anything else is a waste of money until you change out the desmogified cam and low comp. pistons.
If the headlight covers still operate after disconnecting the relay, it's your "HEADLIGHT ON" warning relay/buzzer
Re: so i picked up another mopar! [Re: Commando1] #821976
10/05/10 03:58 PM
10/05/10 03:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
BAH!
Blasphemy!
There is but one path to take.
- Stu Harmon
Re: so i picked up another mopar! [Re: feets] #821977
10/05/10 05:59 PM
10/05/10 05:59 PM
Commando1 Offline
Commando1  Offline
Blasphemy!
Yah. Along with his leaky Thermoquad...
Re: so i picked up another mopar! [Re: Commando1] #821978
10/05/10 06:19 PM
10/05/10 06:19 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Congrats on the purchase!
My guess is the "boiling/gargling" sounds you are hearing is more prominent with the air cleaner lid off, and engine running? If so....
Many of these big blocks used an aspirator tube. This was a low budget (ie: fairly ingenious) way around needing to drive an air pump. Fresh air travels through a small hole in the base of the air cleaner housing, through a tube to a 1 way check valve, then to the back of one of the exhaust manifolds. Exhaust system pulses draw fresh air into the exhaust up-stream of the converter.
The air pulses make a distinct sound when the air cleaner lid is off. If it ain't broke, don't feel obliged to fix it until you remove the catalytic converter. It costs you nothing in horsepower.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: so i picked up another mopar! [Re: DynoDave] #821979
10/06/10 01:39 AM
10/06/10 01:39 AM
E
erick72 Offline OP
erick72  Offline OP
E
lo. its a 400 i shoulda said . and maybe ill just leave the lean burn on if it takes all that. but i wanna get rid of that gargling. is a thermoquad or carter i forgot are they hard to rebuild or should i just clean what ive got. so what would i disconnect to rid of that gargling noise?
Re: so i picked up another mopar! [Re: Commando1] #821980
10/07/10 09:13 AM
10/07/10 09:13 AM
E
erick72 Offline OP
erick72  Offline OP
E
oh yeah also what do you mean the "headlight on" relay buzzer? the buzzing is coming from the healight door relay behind the radio.are you talking about the one behind the pull knob for the headlights?
also i got my switch on the floor for my brights, but there is also a small one closer in by the kick panel. almost indentical to my bright switch? what is it for? i was thinking washer pump.
Re: so i picked up another mopar! [Re: erick72] #821981
10/07/10 09:20 AM
10/07/10 09:20 AM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
The "other switch" on the floor is probably the Search/Scan button for the radio. My dad had one of those new, I used to annoy my buddies when they would mess with the radio, by stepping on that switch and changing stations. I never did tell anybody about that button on the floor.
Re: so i picked up another mopar! [Re: Cuda_Mike] #821982
10/07/10 09:29 AM
10/07/10 09:29 AM
Commando1 Offline
Commando1  Offline
The 78's did not have this. That floor S/S button goes back to a earlier time.
Re: so i picked up another mopar! [Re: erick72] #821983
10/07/10 09:39 AM
10/07/10 09:39 AM
Commando1 Offline
Commando1  Offline
"oh yeah also what do you mean the "headlight on" relay buzzer? the buzzing is coming from the healight door relay behind the radio"
If your headlights are on while the ignition switch is in the off position, do you get a buzzing>
"also i got my switch on the floor for my brights, but there is also a small one closer in by the kick panel. almost indentical to my bright switch? what is it for? i was thinking washer pump."
Never seen that switch on any 74-78 C. The washer pump switch is in the wiper om/off switch.
Re: so i picked up another mopar! [Re: Commando1] #821984
10/07/10 11:55 AM
10/07/10 11:55 AM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
The 78's did not have this. That floor S/S button goes back to a MUCH earlier time.
I guess you're right, it was a '77, but he bought it 8/77 so I was thinking it was a '78...Guess I've never been in a '78...I never realized he bought it used. Must have been a nearly new company car.
Re: so i picked up another mopar! [Re: Commando1] #821985
10/09/10 08:43 PM
10/09/10 08:43 PM
E
erick72 Offline OP
erick72  Offline OP
E
no its when i turn the lights on. the buzzing starts. when i turn the key off it goes away.
so its a search and scan button? hmmmm.
Re: so i picked up another mopar! [Re: erick72] #821986
10/09/10 09:36 PM
10/09/10 09:36 PM
Clinton Twp. Michigan
coronet1966d Offline
pictures!
Re: so i picked up another mopar! [Re: erick72] #821987
10/10/10 10:10 AM
10/10/10 10:10 AM
Commando1 Offline
Commando1  Offline
No, we definately decided it is not a S&S button.
He's right. We need a pic. of it.
Re: so i picked up another mopar! [Re: Commando1] #821988
10/10/10 05:40 PM
10/10/10 05:40 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I wouldn't go so far as to say the 78 440(or 400 for that matter) is the worst 440 ever built. Internally it's no different than any other 70's 440 with smogger low-compression pistons. Just had all the emissions junk tacked onto it, all of which can be removed.
Re: so i picked up another mopar! [Re: erick72] #821989
10/11/10 11:03 PM
10/11/10 11:03 PM
E
erick72 Offline OP
erick72  Offline OP
E
Re: so i picked up another mopar! [Re: erick72] #821990
10/11/10 11:03 PM
10/11/10 11:03 PM
E
erick72 Offline OP
erick72  Offline OP
E
2
Re: so i picked up another mopar! [Re: erick72] #821991
10/11/10 11:04 PM
10/11/10 11:04 PM
E
erick72 Offline OP
erick72  Offline OP
E
3
