holley carb set-up for footbrake #821840
10/04/10 08:23 PM
10/04/10 08:23 PM
Ohio
Dan Brewer Offline OP
Ohio
830 dp currently with a power valve in the front 80 jets. Rear blocked with 88's, jet ext and notched float. Has a bog when you launch at 2000. Not real sure what direction to go to try to get it out.
446" 12.5 CR .620"cam. 5200 convert.
Engine has 9-10" vac idle in gear w/4.5 power valve.
Any suggestions? What other info might you need?
Thanks for any help.
Re: holley carb set-up for footbrake [Re: Dan Brewer] #821841
10/04/10 08:29 PM
10/04/10 08:29 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
squirters check em u should put 40 front and back
Re: holley carb set-up for footbrake [Re: one bad fish] #821842
10/04/10 08:38 PM
10/04/10 08:38 PM
Ohio
Ohio
They are 28, I assume this was stock. 30cc pumps enough? I'll give that a try.
Re: holley carb set-up for footbrake [Re: Dan Brewer] #821843
10/04/10 08:39 PM
10/04/10 08:39 PM
bronx n.y
O
O
bronx n.y
it wil get rid of the stumble
Re: holley carb set-up for footbrake [Re: Dan Brewer] #821844
10/04/10 08:53 PM
10/04/10 08:53 PM
organ
maximum entropy Offline
organ
if the air is good you may need to try 50cc pumps front and rear. holley used to recommend this on all double pumper drag race apps, and many times it is required.
Re: holley carb set-up for footbrake [Re: maximum entropy] #821845
10/04/10 09:03 PM
10/04/10 09:03 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
The larger squirters and a little pump cam tuning should fix it. Also installing a 50cc pump on the secondary side.
Re: holley carb set-up for footbrake [Re: Dan Brewer] #821846
10/04/10 09:17 PM
10/04/10 09:17 PM
Locomotion Offline
Locomotion  Offline
When I ran a power valve, it was about 1.5 - 2 #'s below vacuum at idle. But I had since taken it out and squared the jetting. One less thing to worry about.
The .040" squirters are a big jump, but a good idea. Depends how bad your bog is. If the bog is "initial" you may not need 50cc pumps. Pump cam adjustments/changes may help, if it's even needed. A 50cc pump will basically extend the duration of the squirt creating a too rich condition through the launch. Squirter size determines the initial fuel volume dumped in to cover up the vacuum signal drop when the throttle is slammed open.
Continued fine-tuning squirter size and pump cams can help 60' times more.
Re: holley carb set-up for footbrake [Re: Locomotion] #821847
10/04/10 09:23 PM
10/04/10 09:23 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Dan
I have 28 squirters in my Dominator
Been up in the 40's to get away from a bog myself but didn't help
What's your initial timing at?
Edit; you have 9-10" with a .620 cam what cam is that
Re: holley carb set-up for footbrake [Re: roadhazard] #821848
10/04/10 09:33 PM
10/04/10 09:33 PM
Ohio
Ohio
Hi Greg-
I have crank trigger locked around 34. Its been awhile since I have checke where I had it. Just took the crossram off and never had any poblems w/stock 3705's.
The cam is made by Hughes, I would have to find the cam card. Between 2-3K on the conv I have 12".
PS-new .015 gaskets are working out great!
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: holley carb set-up for footbrake [Re: roadhazard] #821849
10/04/10 09:52 PM
10/04/10 09:52 PM
bronx n.y
O
O
bronx n.y
Dan
What's your initial timing at ?
40 degrees bu i have a small block
Re: holley carb set-up for footbrake [Re: one bad fish] #821850
10/04/10 09:57 PM
10/04/10 09:57 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
WOW! That IS a LOT of vacuum for a .620 lift cam! Must not have all that much duration!
Re: holley carb set-up for footbrake [Re: Dan Brewer] #821851
10/04/10 10:22 PM
10/04/10 10:22 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""Has a bog when you launch at 2000.""
Try moving your primary pump cam to position #2. This will delay the shot. You are wasting some of the pump shot from the cam while bringing up the rpms to 2000. Delay the cam to see if the bog gets better.
Some pump cams have three holes for this purpose. My Demon had three holes on the pink cams to delay the shot.
Re: holley carb set-up for footbrake [Re: YO7_A66] #821852
10/04/10 10:28 PM
10/04/10 10:28 PM
Q
Quicktree Offline
Quicktree  Offline
Q
one thing I see is the power valve is to small with that vac. it should be around 7-8 instead of 4.5. what pump cam do you have?
Re: holley carb set-up for footbrake [Re: Quicktree] #821853
10/04/10 10:32 PM
10/04/10 10:32 PM
Locomotion Offline
Locomotion  Offline
"Late", not "small". Flow is the same regardless of #.
Re: holley carb set-up for footbrake [Re: Locomotion] #821854
10/04/10 10:36 PM
10/04/10 10:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats what I was talking about. being late could cause the stumble
Re: holley carb set-up for footbrake [Re: Dan Brewer] #821855
10/04/10 10:41 PM
10/04/10 10:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
Does your 830 DP have annular boosters? If so or if not either way try some # 35 or # 37 size squirter in front and back first, the 28 will probally work real well when it is hot and humid, save them. I have removed more 50 CC pumps from Holley DP than I have installed them on, it is very easy to make the car bog by having to little pump squirt or to big pump squirt You need enough pump squirt to make the transition from either the idle or transition circuit at that low RPM, probally the transition circuit. I have seen cars that are on the primary main circiut at or above 2300 RPM against the converter and didn't need much pumnp shot from there to launch wellMy message is don't spend money that you don't need to, squirters are a lot cheaper than 50 CC pumnps
Re: holley carb set-up for footbrake [Re: Cab_Burge] #821856
10/04/10 10:53 PM
10/04/10 10:53 PM
Renton Washington
Triple Threat Offline
Renton Washington
Even on my little engine I run a 35 in the rear.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: holley carb set-up for footbrake [Re: Triple Threat] #821857
10/04/10 11:36 PM
10/04/10 11:36 PM
Ohio
Ohio
Annular boosters, the pump cams are white. I have a pr of 37 squirters so I can try them. I always thought that you divide the idle vac by 2 and that is a good starting point for the pv's I haven't been to the track yet but I do have 80' of new concrete that is getting broke in proper. Thanks for all the input, I have some things to try now.
Re: holley carb set-up for footbrake [Re: Dan Brewer] #821858
10/04/10 11:41 PM
10/04/10 11:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you may get away with the dividing thing on a stock street car but it doesn't work well with performance combo's. also try a more aggressive cam like a brown or blue if the bigger squirters don't work. I myself like the 50cc pumps. you can use a smaller squirter.
Re: holley carb set-up for footbrake [Re: Quicktree] #821859
10/05/10 11:13 PM
10/05/10 11:13 PM
Ohio
Ohio
-Update-
So I switched the squiters from 28 to 37's. I had them so I gave them a try. Seems to have fixed the problem. Flashing the conv in high or launching the car feels great. I have some other pv's and cams on the way so I can tinker with them. Going to the track thurs for the real results. Anyone want to take a guess if the single 4 will be quicker/slower than the mw crossram and carters in similar air?
Thanks again for the help/suggestions.
