Question about inner fender replacement (B Body) #821087
10/03/10 08:42 PM
10/03/10 08:42 PM
California
BigDaddy440 Offline OP
California
The only two panels that I need to replace on my 69 Roadrunner are the inner fenders. They were cut into for headers etc. My paint and body guy said he could do it.
Question:
What steps can be taken to assure that when the inner fenders are replaced, the upper A-arm suspension geometry is not "off" or changed for the worse?
I'm sure AMD could tell me, but I'm also wondering if these panels include the section / provision for the upper A-arm to mount to.
Thanks for any advice or information.
-dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Question about inner fender replacement (B Body) [Re: BigDaddy440] #821088
10/03/10 09:26 PM
10/03/10 09:26 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
If the structure is sound (just guessing it is because you're from Calif) then why not find a donor car to cut patches from and weld those back in?
Re: Question about inner fender replacement (B Body) [Re: BigDaddy440] #821089
10/03/10 09:36 PM
10/03/10 09:36 PM
Southeastern MI.
Q
QuickSilver Offline
mopar addict
QuickSilver  Offline
mopar addict
Q
Southeastern MI.
Dan, Here is a inner fender repair job that I did recently for a fellow member as well as altering the shock tower. It is an early B body but still similar to what you are asking about. The control arm bracket is separate from the actual inner fender panel. It is spot welded around the outer perimeter of the control arm bracket, which itself is welded to the top of the frame rail. If it is just the inner fender that was trimmed out for header clearance then that is all that I would replace. Now if they went crazy and got into the A-arm bracket then that is a different matter. You can change just the inner fender panel without having to fool around with the bracket, it is pretty solid the way it is mounted to the frame rail and I wouldn't worry about the geometry being off. Good Luck! JC.
Re: Question about inner fender replacement (B Body) [Re: Quikshft] #821090
10/08/10 12:35 AM
10/08/10 12:35 AM
California
California
The inner fenders are sold (no rust) but they're cut up pretty well. Welding in some patches is a good idea...thanks.
I appreciate the responses, thanks!
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
