440 with a trace of white grease on the dip stick???? #820827
10/03/10 02:12 PM
10/03/10 02:12 PM
indiana,usa
donsbelvedere Offline OP
indiana,usa
new 440 engine after break in changed oil ran it or 2min and check fluid level and noticed small trace of what looks like the white lithumn grease I used for assembly of the motor.....is that posible...thanks
Re: 440 with a trace of white grease on the dip stick???? [Re: donsbelvedere] #820828
10/03/10 02:21 PM
10/03/10 02:21 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
It's possible, but it could be coolant or condensation. Are you running straight water? Keep an eye on the coolant level. Look for bubbling int the rad. If you have a pressure tester, check and make sure the system is holding pressure. It's probably nothing, but it doesn't hurt to be safe.
Re: 440 with a trace of white grease on the dip stick???? [Re: torkrules] #820829
10/03/10 10:57 PM
10/03/10 10:57 PM
hudson valley n.y.
GEORGE68HEMIRR Offline
super street
super street
hudson valley n.y.
yes do as he said and if the oil turns milkey brown you may have a head gasket going or not sealing correctly
