Re: Duster alignment with Moog bushings
[Re: WILD BILL]
#820476
10/03/10 02:45 AM
10/03/10 02:45 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
You have them backwards for max caster.
Here is a passenger side A-body upper with offset bushings. Look at the washer on the front bushing. The washer and center hole is toward the motor. And the rear washer is offset toward the fender.
[Re: Kern Dog]
#820478
10/08/10 09:31 PM
10/08/10 09:31 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I finally got a chance to pull the car in and get a look. I have the bushings in correctly, with the offsets facing as follows: Front bushing offset towards engine. Rear bushing offset towards fender. Could the alignment guy just be having a bad day? I would think that with a car that hasnt been wrecked should align right without these bushings, and WITH them, I should be able to get far more caster than stock. Any ideas?
[Re: Kern Dog]
#820479
10/08/10 10:27 PM
10/08/10 10:27 PM
autoxcuda
So Cal
Do the cams sort of look like this...
[Re: Kern Dog]
#820480
10/08/10 10:48 PM
10/08/10 10:48 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
The statement by the alignment guy, of the more negative camber = more negative caster is wrong. EDIT
I never did like the Tip of reversing the rear bushing.
Sure, It will give the upper controll arm Caster adjustment its greatest sweep. That is Correct!
But by reversing that rear bushing it will also pull negative camber in sooner. Witch will limit your positive Caster adjustment by your desired Camber.
The camber "adjustment spec" is stopping your alignment guy from giving you more positive caster.
I Bet he could get you some more positive caster at the expence of negative Camber.
My idea, put the rear moog offset bushing in as recommended, offset towards the engine. That will make the upper control arm longer.
Your alignment guy may have extra positive camber to play with while trying to pull some positive caster. mike
Edit; Your alignment guy has made some mistatements or you have misinterpreted some things or both.
