440 EZ Indy head question #820166
10/02/10 08:50 PM
10/02/10 08:50 PM
Moparnocar Offline OP
super street
super street
We installed the 440 EZ head on today and forgot about the valley pan wont work. What's my options or what do I need to buy to make this work? thanks
Re: 440 EZ Indy head question [Re: Moparnocar] #820167
10/02/10 09:00 PM
10/02/10 09:00 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
So you dont have a plate covering the valley either?
I thought that you could still use "bathtub" intake gasket with the EZ's.
I just have the valley plate and paper gaskets on mine.
Gus
64 Plymouth Savoy
Dana 60
Re: 440 EZ Indy head question [Re: fourgearsavoy] #820168
10/02/10 09:06 PM
10/02/10 09:06 PM
super street
super street
The heads I have accept any aftermarket intake. not the indy one yet. If u put the factory valley plate on, it sits about a 1/2" high of the block. cause these heads are taller. I'm not sure if they make special gaskets for the front and back or have to go a different route.
Re: 440 EZ Indy head question [Re: Moparnocar] #820169
10/02/10 11:25 PM
10/02/10 11:25 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Which block?
Felpro #1215 for an RB and #1214 for a B block.
Re: 440 EZ Indy head question [Re: Moparnocar] #820170
10/03/10 12:49 AM
10/03/10 12:49 AM
AndyF Offline
AndyF  Offline
You need a special valley plate to work with the Indy heads. It fits under the heads so that means you have to take the heads back off to install the valley plate. I use a plate with a removeable center section so I can change the cam without pulling the heads.
Re: 440 EZ Indy head question [Re: AndyF] #820171
10/03/10 10:27 AM
10/03/10 10:27 AM
Western NY
maxi426 Offline
maxi426  Offline
Western NY
Indy also sells aluminum 1/2" spacers to put on the block to take up the space between the block and the pan.
