Re: What should this cost?
[Re: Russ]
#82009
07/01/08 12:55 PM
07/01/08 12:55 PM
Posts: 3,753 Gulf Coast of Florida
Russ
super gas
super gas
took out the thermostat,put the plugs back In,and drove it about 3 miles,now It feels like It's running on 3 cylinders at a stop sign,but clears up when I take off,got back home,and the coolant Is gurgling Into the overflow tank ![](/ubbthreads/images/graemlins/flame.gif)
2001 Durango 5.9 Magnum
99 Durango 5.9 Magnum
Parting out 99 Durango 5.9,99 Ram 1500 and 98 Ram 1500 5.9
WANTED.Ram Truck,Durango/Dakota parts and parts trucks!!PM Me.
GO BUCKS!!!!
Go GATORS!!!!
[Re: Russ]
#82011
07/01/08 02:11 PM
07/01/08 02:11 PM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I told you how to diagnose it.
[Re: Russ]
#82012
07/01/08 03:15 PM
07/01/08 03:15 PM
DaytonaTurbo
Manitoba, Canada
Okay, I over heated my 87 daytona a few times and the problem never was a head gasket. In fact I never did have to do a head gasket in that car even after really overheating it a few times. Turns out the problem was a plugged heater core. For some reason on these cars, once the heater core plugs, the motor overheats. More so it's noticeable because the temp gauge swings back and forth a lot, where when the cooling system is functioning properly the needle doesn't move once you get up to operating temp. Not wanting to have to change the heater core, I gave the entire cooling system a good flush, then spent some time flushing the heater core. Then refilled the entire cooling system with distilled water/coolant, blurped the cooling system and guess what? No more overheating. All the head gasket changes in the world wouldn't have fixed that problem for me.
[Re: Russ]
#82014
07/02/08 09:27 PM
07/02/08 09:27 PM
Russ
super gas
super gas
took It to 3 different places,and all said,the motor was shot,and not worth even an engine swap,so i took it to the crusher,and bought this
GO BUCKS!!!!
Go GATORS!!!!
