AMD parts are AMAZING!!! #819914
10/02/10 12:33 PM
10/02/10 12:33 PM
Finally a HUSKER again
Moparnut426 Offline OP
We got our quarters from AMD for the 73 `Cuda, and I have to say they are VERY impressive. Thanks Corey, We bought the car wi a set of Full goodmarks, and we sold them thinking the skins on the car were gonna work, Well NOPE, we found rust coming through the "new" skins on the car, so we decited to do it once and not worry about it later. So as a comparison the AMD quarters are crisper, thicker, and have every factory dimple, kink, crease, everything. The goodmark quarters were not as crisp, were missing the factory dimple in the rocker, and they looked and felt flimsy.
Hats off to AMD, I hope to see more parts from them in the future.
And thanks Corey for saving me some cash on the parts.
Kasey
Re: AMD parts are AMAZING!!! [Re: Moparnut426] #819915
10/02/10 01:10 PM
10/02/10 01:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
double check the fit of the rear qtr window cat wiskers mounting location, much easier to modify before you put it on the car
Mike
Re: AMD parts are AMAZING!!! [Re: Moparnut426] #819916
10/02/10 01:15 PM
10/02/10 01:15 PM
South Dakota
hotairballoonpilot Offline
South Dakota
No problem! Glad I could help! Now come on fenders! Right!!
Contact Me about AMD Prices
Re: AMD parts are AMAZING!!! [Re: hotairballoonpilot] #819917
10/02/10 08:30 PM
10/02/10 08:30 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
What are you AMD guys hearing on the challenger fenders? Is the end of the year reallistic?
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: AMD parts are AMAZING!!! [Re: Moparnut426] #819918
10/02/10 08:54 PM
10/02/10 08:54 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
We use a lot of AMD sheet metal and have been extremely pleased with it. We have installed valance panels, fenders, hoods, complete passenger floor pans, trunk floor pans, rear body panels, etc.
Just recently I had my first problem with a stamped part. It's a right side 68-70 B-body door skin. It's formed wrong at the front top area where it meets the door. I'll be adding and subtracting some metal along the flat upper door edge where it is supposed to curve to prevent hanging on the fender.
Not a big deal, unless you have painted the inside of your door. Another good reason why we always test fit our panels before doing any paint work.
Steve
www.clarkclassic.com
Re: AMD parts are AMAZING!!! [Re: Moparnut426] #819919
10/02/10 10:10 PM
10/02/10 10:10 PM
Jacksonville Florida
elitecustombody Offline
That's what I keep telling everyone, nothing compares to AMD
Re: AMD parts are AMAZING!!! [Re: BarrsRestoration] #819920
10/03/10 01:22 AM
10/03/10 01:22 AM
South Dakota
South Dakota
Steve
Please make sure you or anyone else if you see something that isn't right contact any of us or AMD so they know. FYI I put a charger hood on and found that the hood pad holes were just a little small compared to not only the new clips but the original clips. Took a small redrilling but I told AMD and they were going to address that on the next run. As far as the ebody fenders I am hearing if they pass this time it is about 90 days out. Last I heard they were just about there. Fingers crossed
Re: AMD parts are AMAZING!!! [Re: hotairballoonpilot] #819921
10/03/10 03:05 AM
10/03/10 03:05 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
How is the AMD glass for e-bodies? Anyone have any feedback. I see that it's licensed by Mopar.
Re: AMD parts are AMAZING!!! [Re: jbc426] #819922
10/03/10 09:17 AM
10/03/10 09:17 AM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
I've sold and installed Ton's of AMD parts now without any major complaints... Any issues we've had , have taken little to no time to correct...
They definetaly have the best metal available...
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: AMD parts are AMAZING!!! [Re: fireeng] #819923
10/03/10 09:20 AM
10/03/10 09:20 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
They are in final tooling. I test fitted them. Just a couple minor tweaks,and they will be ready for production.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: AMD parts are AMAZING!!! [Re: jbc426] #819924
10/03/10 11:17 AM
10/03/10 11:17 AM
Owosso, Michigan
stateroadhog Offline
Owosso, Michigan
I was going to buy glass for my b-body but, after my nieghbor bought door glass for his cuda and it didn't fit (warped so bad couldn't install sent another one same thing) i am now not sure what to do!!
Re: AMD parts are Ok [Re: stateroadhog] #819925
10/03/10 01:29 PM
10/03/10 01:29 PM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
The glass I have installed on several cars and I like Pilkington's better Than AMD. The AMD Glass has a lot of tong marks and had a few blemishes in the glass. The best I think is PPG. More costly but way better quality. The only real good thing on AMD is the Chrysler logos on the glass.
Re: AMD parts are AMAZING!!! [Re: stateroadhog] #819926
10/03/10 01:43 PM
10/03/10 01:43 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
That doesn't sound good, but I understand they are addressing the e-body door glass issue and are expecting the new ones mid-October.
Re: AMD parts are Ok [Re: Dartman440] #819927
10/03/10 01:46 PM
10/03/10 01:46 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Who carries the PPG stuff? ECS?
