Re: What makes NHRA Stock cars so quick? [Re: The Wolf Man] #819609
10/02/10 12:56 PM
10/02/10 12:56 PM
Emmett, Idaho
SuperStockWagon Offline
Emmett, Idaho
Making everything work together to the Nth degree..plus a ton of R&D on different combos and components..I know of a record setting 360-4bbl F-Body combo that they thrashed for 15+ years to get it where it is today,its fully capable of 1.30+ under the current index of 12.30 in qualifying trim and 100% legal. Depending on the class and combo its not as much money as it is time,time and more time.
NHRA Stock/SuperStock Class Racing..Engineered Muscle In Motion!
Re: What makes NHRA Stock cars so quick? [Re: theclutcher] #819610
10/02/10 01:03 PM
10/02/10 01:03 PM
Indianapolis Indiana
Jamie340 Offline
Jamie340  Offline
The other half of the equation is knowing how to get a car on 9 inch tires down the track, efficiently. Those costs are no different than bracket car. What does cost are the trials and errors that it takes to find out what the car likes. You can have all the power in the world but if the combination is wrong it is all for not.
Jamie
Re: What makes NHRA Stock cars so quick? [Re: SuperStockWagon] #819611
10/02/10 01:09 PM
10/02/10 01:09 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
A couple of things those guys have told me over the years has just astounded me, how the heck does a person even begin to think the way they do,LOL. Stock was always my favorite class, they do the most with the least.
Re: What makes NHRA Stock cars so quick? [Re: jake4cars] #819612
10/02/10 01:22 PM
10/02/10 01:22 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Push the envelope.
Tolerances for crank shaft stroke are + - .015 if I recall.
So most cranks are offset ground + .015.
I don't know about re-locating bores , but if there is a spec , you have to know that the parts are right up against it.
Back when Jason Line ran stock , he won an event at Brainerd only to be D.Q.'ed for " modified " pistons.
The valves had touched off during valve float and left witness marks on the pistons.........a 455 Buick as I recall.
It was determined that the pistons were notched for valve clearance ......intentionally or not , and he was robbed I.M.O.
But a stock 455 isn't going to put a valve near a piston unless you break a timing chain.......and that is a maybe.
Re: What makes NHRA Stock cars so quick? [Re: tubtar] #819613
10/02/10 02:03 PM
10/02/10 02:03 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Most of those guys have been running Stock for 20 years, a lot of them with the same car. I see them in Ennis and a lot of them are the same car or combo. Mike Cotten has been running green Dusters (I think he's gone between the 340 LC and the 360) for the last 25 years. Vern Buchanan has been running that same Mustang for just as long. I'm sure they have crates of parts at the shop that they tried.
Floyd Lippencott IV
Re: What makes NHRA Stock cars so quick? [Re: mr_340] #819614
10/02/10 02:24 PM
10/02/10 02:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Searching through piles of heads to find the best, searching through piles of intakes to find the best, I have heard of guys running 20 different identicle intakes on a dyno to find as much as 25 hp differance from the best to the worst, that takes a lot of time and money, then they acid port them to open them right up to the max CC and if they go too big then they can mill them the maximum allowable amount to get the CC back down. Some of them will dyno test cams changeing only one timing event per cam to find the best intake closeing point, the best intake opening point, the best exhaust opening point and the best exhaust closeing point since lift is limited. They will change things mabey two degrees at a time to find the 4 absolute best possible points. The guys running hydraulic cams will fool with the lifters to make them basically a solid so they can turn a few more RPM. Also you better beleive they are looking to move the cylinder walls away from the intake valves, they will play around with valve jobs to get the absolute highest flow, some of them beleive in indexing the plugs while some guys swear there is no differance.
Then they move on to the trans and find the lightest parts they can find, and make sure everything is lined up perfectly to reduce friction and in an auto they make the trans shift very fast with the absolute minimum line preasure they can get away with because high preasure takes away hp, then they make sure the u-joints are in prefect alighnment to reduce power robbing miss-alighnment, in the rear they make everything line up perfect to re-duce friction. Drum brakes are gonna be adjusted to not cause any drag at all. Suspension components are gonna be blue printed to allow just right amounts of front end lift yet keep the front down low to reduce drag. Alighnments are set to perfection to let the car roll easiest under power... nothing is left to chance everything is checked and re-checked like you wouldn't beleive. The guys who say it is just time and not so much money just have a different perspective on what money really is.
Re: What makes NHRA Stock cars so quick? [Re: The Wolf Man] #819615
10/02/10 07:41 PM
10/02/10 07:41 PM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, I'd like to clarify couple misquotes, first, the cam can be any duration, stock lift required. second,a pan evac system is not allowed or vac pumps either. it does take money, however, lots of work and effort. you have to think outside the box, so to speak. hot rod mag and internet do not build stockers. its true, not all castings are equal!!
Re: What makes NHRA Stock cars so quick? [Re: perfmachst] #819616
10/02/10 09:35 PM
10/02/10 09:35 PM
indiana
moparbrown14 Offline
indiana
talked to a guy at indy a couple of years ago and he ran a parts store. they would order brake drums just to weigh them and take the lightest ones. he said some were as much as 4 lbs lighter. i just wish i could afford a stocker or super stocker
Re: What makes NHRA Stock cars so quick? [Re: perfmachst] #819617
10/02/10 09:39 PM
10/02/10 09:39 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Alot more than just the motor, rollerized trans, aluminum brakes, gun-drilled axles, lightened gears, synthetic fluids...reduced friction is what gets it done. The guy that does my heads has a K/S car with a Jericho trans and he has a Racepak on board, hooks it up to a laptop after each run just like a Pro-stocker. He also has a Superflow bench in his modest 2-car garage and has spent countless hours flowing 4-G carbs to find the best one possible.
Re: What makes NHRA Stock cars so quick? [Re: HotRodDave] #819618
10/04/10 09:51 AM
10/04/10 09:51 AM
mi
V
vcummins Offline
vcummins  Offline
V
mi
Now we are getting closer
Re: What makes NHRA Stock cars so quick? [Re: The Wolf Man] #819619
10/04/10 01:46 PM
10/04/10 01:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
When I worked at Pettis Performance we built some "stocker" motors that were everything but stock. But I`ll say that the motor is only part of the performance these things show. $7,500 trannies,lube tricks in motor,trans and rear etc. I wish I could say more but that could cost me my life.
Re: What makes NHRA Stock cars so quick? [Re: Thumperdart] #819620
10/05/10 12:36 AM
10/05/10 12:36 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Dude if I could tell you the things I have heard out of a group of local stock racers.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: What makes NHRA Stock cars so quick? [Re: Irun5snd8th] #819621
10/05/10 10:37 AM
10/05/10 10:37 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Lots of Money$$, and who can cheat the best.
One day I will have something cool here.
Re: What makes NHRA Stock cars so quick? [Re: sdaurity] #819622
10/05/10 11:00 AM
10/05/10 11:00 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
A good Stock racer from the area told me once, "Rules are written in black and white, a good racer finds the grey area." Jason Lines family lives eats and breaths Stock Eliminator racing. Mom, Dad, Brothers, and cousins, all run Stock. It's ALL they do period.
Now another thing to consider, alot has changed over the years of running stock. aftermarket disc brakes are legal, and SOME aftermarket heads are legal also. The heads on Lance Lines CJ 69 Mustang NEVER came on a production car...
69 GTX 68 Road Runner
Re: What makes NHRA Stock cars so quick? [Re: sdaurity] #819623
10/05/10 11:06 AM
10/05/10 11:06 AM
Colorado Springs, Colorado
Dartthunder340 Offline
Interpretation of the rules.
Better get inside Ma. Looks like a storm's comin'.
Re: What makes NHRA Stock cars so quick? [Re: Dartthunder340] #819624
10/05/10 02:17 PM
10/05/10 02:17 PM
The fastest cars in a class have the best parts, work harder and smarter than all the rest of the guys racing that class As already said if your not experimenting on your combination your getting left behind Bottom line is how hard are you willing to work and how much money do you want (can or willing)to spend
