Is it time for me to change my oil? (brand/viscosity)
#818753
10/01/10 12:26 AM
10/01/10 12:26 AM
Posts: 469 In a van, down by the river
jmf340
I have a 2000 Dodge Intrepid R/T, 3.5 w/auto stick. I run Valvoline full synthetic 10w-30. It will usually use about 1/2 qt. between oil changes (5000 mi) but it seems to be using a little more than usual now. It has 106,000 on it. I was thinking about going with a high mileage oil or is that stuff just a gimmick? Maybe go back to conventional? What do you guys think?
Got Mopar???
Re: Is it time for me to change my oil? (brand/viscosity)
[Re: jmf340]
#818754
10/01/10 09:14 AM
10/01/10 09:14 AM
Posts: 905 SD
zrxkawboy
SD
A half quart per 5k is sure not excessive in my book. However, if you feel the need to try a HM oil, Maxlife is excellent. They have both a syn blend (group II/III) and a syn (group III) version.
It's Swifty! Swifty, you toad sucker!
[Re: StandOnIt]
#818757
10/03/10 12:52 AM
10/03/10 12:52 AM
jmf340
Thanks for the replies. The water pump and timing belt were already replaced at about 98K. I'll just stick with what has been working.
Got Mopar???
