Is it time for me to change my oil? (brand/viscosity) #818753
10/01/10 12:26 AM
10/01/10 12:26 AM
In a van, down by the river
jmf340 Offline OP
jmf340  Offline OP
I have a 2000 Dodge Intrepid R/T, 3.5 w/auto stick. I run Valvoline full synthetic 10w-30. It will usually use about 1/2 qt. between oil changes (5000 mi) but it seems to be using a little more than usual now. It has 106,000 on it. I was thinking about going with a high mileage oil or is that stuff just a gimmick? Maybe go back to conventional? What do you guys think?
Got Mopar???
Re: Is it time for me to change my oil? (brand/viscosity) [Re: jmf340] #818754
10/01/10 09:14 AM
10/01/10 09:14 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
A half quart per 5k is sure not excessive in my book. However, if you feel the need to try a HM oil, Maxlife is excellent. They have both a syn blend (group II/III) and a syn (group III) version.
It's Swifty! Swifty, you toad sucker!
Re: Is it time for me to change my oil? (brand/viscosity) [Re: jmf340] #818755
10/01/10 12:51 PM
10/01/10 12:51 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
106,000 miles on a 3.5L, it should still be in great shape. Normal maintance at that mileage is a new timing belt and water pump. I did mine at 120,000 miles and the belt still looked good, but I'd rather error on the safe side.
I would not worry about using a high mileage oil, but I don't think it would hurt either.
Re: Is it time for me to change my oil? (brand/viscosity) [Re: 451Mopar] #818756
10/02/10 03:28 PM
10/02/10 03:28 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Roller camshaft engines are not high mileage at 110k miles. I would stick with the synth oil and do the required maint. Use a good upper end treatment in your fuel every once in a while and keep driving.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Is it time for me to change my oil? (brand/viscosity) [Re: StandOnIt] #818757
10/03/10 12:52 AM
10/03/10 12:52 AM
jmf340 Offline OP
jmf340  Offline OP
Thanks for the replies. The water pump and timing belt were already replaced at about 98K. I'll just stick with what has been working.
Got Mopar???
