Tranny fluid question #818577
09/30/10 07:34 PM
09/30/10 07:34 PM
MS, USA
K
killercoronet Offline OP
K
MS, USA
I have a 440/727 combo i checked my fluid and i overfilled it a bit. My question is will this make it drag and not shift good cause it doesnt seem right. Also whats the best way to drain it?
Re: Tranny fluid question [Re: killercoronet] #818578
09/30/10 08:19 PM
09/30/10 08:19 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
I believe the worst thing about being overfull is the spinning parts can make bubbles in the fluid. You can either drain a little out of the converter if it has a plug, remove the neutral safety switch or break loose a cooler line.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
