Poly 318 with 331 Hemi heads #81836
06/29/08 08:03 PM
06/29/08 08:03 PM
Eastern Ohio
mopowergtx Offline OP
Eastern Ohio
I was asked today if you could run 331 Chrysler Hemi heads on a poly 318. I had no answer to that. Anybody ever heard of that one before?
Re: Poly 318 with 331 Hemi heads [Re: mopowergtx] #81837
06/29/08 08:30 PM
06/29/08 08:30 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Don't know how it could be done. different configuration
Re: Poly 318 with 331 Hemi heads [Re: MoparforLife] #81838
06/29/08 08:39 PM
06/29/08 08:39 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I was thinkin that they will work but the pistons were different in valve notches. I never have tried this but thought I read it somewhere
MM
Re: Poly 318 with 331 Hemi heads [Re: mopowergtx] #81839
06/29/08 08:48 PM
06/29/08 08:48 PM
No, 331 Chrysler and 318 poly are completely different engines with different bore spacing (i.e., different distance between cylinder bore centers).
You can put Chrysler hemi heads on a Chrysler poly, and Dodge hemi heads on a Dodge poly.
There are no poly versions of the De Soto hemi, and no hemi versions of the Plymouth poly,
BUT some 55-6 Plymouths and some 57 De Sotos used Dodge poly engines and you CAN put Dodge hemi heads on them.
The 56-8 Plymouth poly became the corporate Chyrsler small block in 59, used in both Plymouth and Dodge from then on; later developed into the 318 wedge and used eventually in not only Plymouths and Dodges, but also Chryslers, BUT, it was originally developed by Plymouth for Plymouths.
Re: Poly 318 with 331 Hemi heads #81840
06/29/08 11:21 PM
06/29/08 11:21 PM
Ok, now I think I'm going to throw up from my head spinning so much!
