how heavy is a cage
#817295
09/29/10 10:25 AM
09/29/10 10:25 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
how much weight will a 12 point MS or CM cage add to a car?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: how heavy is a cage
[Re: sixpackgut]
#817297
09/29/10 10:51 AM
09/29/10 10:51 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Ray...My 10 point mild steel cage added roughly 110 lbs.
[Re: sixpackgut]
#817298
09/29/10 03:53 PM
09/29/10 03:53 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
I may be off-base for what you are looking to have answered, but if you are trying to determine strictly by weight how much a cage will slow your car, you may also need to consider the cage will stiffen the chassis.
Normally you can figure 100# = .10 sec in E.T., but with a cage there is less energy wasted flexing the car and more power getting to the tires, so it may not affect E.T. as much.
Scott
[Re: ProStDodge]
#817300
09/29/10 05:18 PM
09/29/10 05:18 PM
sixpackgut
Charleston
Scott
I just wanted an idea of how much weight it would be as i had no idea.
