how heavy is a cage #817295
09/29/10 10:25 AM
09/29/10 10:25 AM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
how much weight will a 12 point MS or CM cage add to a car?
Re: how heavy is a cage [Re: sixpackgut] #817296
09/29/10 10:34 AM
09/29/10 10:34 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Mine is 10 point MS and the pipe weighed 134 lbs. It's in a 69 Dart. Jim
Re: how heavy is a cage [Re: sixpackgut] #817297
09/29/10 10:51 AM
09/29/10 10:51 AM
an8sec70cuda Offline
Ray...My 10 point mild steel cage added roughly 110 lbs.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: how heavy is a cage [Re: sixpackgut] #817298
09/29/10 03:53 PM
09/29/10 03:53 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I may be off-base for what you are looking to have answered, but if you are trying to determine strictly by weight how much a cage will slow your car, you may also need to consider the cage will stiffen the chassis.
Normally you can figure 100# = .10 sec in E.T., but with a cage there is less energy wasted flexing the car and more power getting to the tires, so it may not affect E.T. as much.
Scott
Re: how heavy is a cage [Re: sixpackgut] #817299
09/29/10 04:16 PM
09/29/10 04:16 PM
Cab_Burge Online work
Cab_Burge  Online Work
I thank your first question should be which is stronger and which is best and what are your reasons for thinking and saying that I have been told by many racers, budget and top dollar racers, that chromoly it is stronger, lighter and it has memory and is harder to bend, especially in a wreck and it ends up protecting the driver better They thank it is better in a drag race car I had my street/strip cars roll bar and sub frame connectors done with chromoly for those reasons To get the answer on the weight try calling some of the better chassis makers that sell kits and ask about the weight for a kit for your car in MS and chromoly
Re: how heavy is a cage [Re: ProStDodge] #817300
09/29/10 05:18 PM
09/29/10 05:18 PM
Charleston
Charleston
Scott
I just wanted an idea of how much weight it would be as i had no idea.
Re: how heavy is a cage [Re: sixpackgut] #817301
09/30/10 08:13 AM
09/30/10 08:13 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Weight is not the Issue;Your Life Is,One of those things u hope u never have to use.Go with Chrome Molly for weight savings,
Re: how heavy is a cage [Re: sixpackgut] #817302
09/30/10 08:20 AM
09/30/10 08:20 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Almost as much as one of your doors
Re: how heavy is a cage [Re: poisondart2] #817303
09/30/10 10:07 AM
09/30/10 10:07 AM
ProStDodge Offline
ProStDodge  Offline
OK - That's funny! And probably true!
Re: how heavy is a cage [Re: ProStDodge] #817304
09/30/10 11:07 AM
09/30/10 11:07 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
For a adverage guestament,MS-2.5 lb/ft and CM-1.5 lb/ft for all large main tubes@ 1-5/8"
