Re: STAGE V Engineering... Hemi heads on a 440 block
[Re: JohnRR]
#817157
09/29/10 10:47 AM
09/29/10 10:47 AM
Posts: 1,001 Canada
Ghoste
Canada
It was a viable option when it first came out and then Chrysler brought the Crate Hemi's back into the picture.
I see a light at the end of the tunnel, and it's... ELECTROLUMINESCENT!
[Re: maximus]
#817161
09/29/10 12:22 PM
09/29/10 12:22 PM
DaytonaTurbo
Manitoba, Canada
Looked into it years ago, you have to run external oil lines from the front of the block to the heads.
I thought it was just an external oil drain line. The way I heard it was they blocked the front drain hole and the rear drain hole you had to add a drain line to go into the block or pan. Really not a big deal to do that.
[Re: maximus]
#817162
09/29/10 12:22 PM
09/29/10 12:22 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Front and back of heads to the pan for oil drain back.
As said it was the thing to do when Hemi blocks were hard to come by and $$$$
[Re: mr_340]
#817164
09/29/10 02:10 PM
09/29/10 02:10 PM
JohnRR
I guess they are more available but still seem $$$$ to me.
Yes they are pricey but not as pricey as they were when these heads originally came out.
[Re: JDMopar]
#817168
10/01/10 11:31 PM
10/01/10 11:31 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
A friend of mine built a 528" Stage V Hemi for his 67 GTX back in the early 90's. It went 10.20's thru the mufflers on Hoosier QTP's. He did scatter it one time because the bottom end gave up. Luckily didn't hurt the heads, so he got another block and rebuilt it. It stayed together fine after installing the billet main caps.
Billet main caps and ARP studs on a 72'73 3614230 casting 400 block. Bullet proof? Beefiest bottom end of any B/RB block, but still not cross drilled.
[Re: six-pack-mopar]
#817170
02/08/11 06:01 AM
02/08/11 06:01 AM
Posts: 3 Ca
Jeff_Mopar
Ca
I have a set of these Stage V Heads they are of a very high quality from Stage V engineering. I have yet to build it as I am looking for a 1971to 72 400 3614230 thick mains or saddles for strength and thicker cylinders. But I have also considered trading them for a set of Stage 6 Chapmans 285 MW heads with the valves & rockers. If anyone knows of a block or wants to trade for the heads let me know.
[Re: Jeff_Mopar]
#817171
02/08/11 02:12 PM
02/08/11 02:12 PM
JohnRR
What are you going to do about an intake ?
