Air grabber switch #81710
06/29/08 05:32 PM
06/29/08 05:32 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I just purchased a new air grabber switch and just out of the box there only seems to be about 1/8 inch travel on the switch. Is that normal or should I suspect something is wrong with the switch? Or does it make a difference if it is hooked up to the vacuum? TIA
Re: Air grabber switch [Re: gregok] #81711
06/29/08 05:39 PM
06/29/08 05:39 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Here is a video of a switch I am selling on Craigs List.
It should help you see if your switch is working ok.
If you have any guestions e-mail me at Convx4@yahoo.com
http://www.youtube.com/watch?v=U_8DfdQh-7Q
Re: Air grabber switch [Re: convx4] #81712
06/29/08 06:33 PM
06/29/08 06:33 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Thanks for the information. Apparently my switch is defective as it doesn't travel even as close to the one you demonstrated.
