hood pin stud location
#816976
09/28/10 09:34 PM
09/28/10 09:34 PM
Posts: 13 northeast
f6bee
northeast
can someone help me out as to the location of where the hood pin stud goes?i'm talking about the hole that i need to drill on the fender bracket.It is for a 69 383 superbee.thanks for your help
Re: hood pin stud location
[Re: f6bee]
#816977
09/28/10 10:14 PM
09/28/10 10:14 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
The holes in my '72 Charger were there in the fender bracket. You can see it at the center-bottom of the picture. Sorry I never took a picture after installing them in a clean engine compartment.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: f6bee]
#816978
09/28/10 10:17 PM
09/28/10 10:17 PM
dfsmopars
Kentucky
Here you can see where they turned out in the hood. This may not help at all with your '69 but there's not too many questions I can answer, with confidence, on this forum. So I like to help where I can.
[Re: mymcodebee]
#816980
09/29/10 01:26 AM
09/29/10 01:26 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
yes, and provisions are there.
on my 74 charger just did need to cut the outer skin, not even the bottom frame of the hood. ( except for bezel screws ).
I think you should find easilly the hole already there for the stud
You'll find even the wire screw provision
[Re: Mr.Yuck]
#816983
09/29/10 12:42 PM
09/29/10 12:42 PM
Posts: 322 Itasca, Texas
Mad_Scientist
Itasca, Texas
Just remove the inner bolt for the core support, and that is the hole the factory used for the hood pin.
69 Super Bee 440 5-speed 70 Dart Swinger 340 4-speed 69 Camaro SS 396 4-speed 66 Cutlass Convertilbe 70 Judge Ram Air III 4-speed 68 F-100 SWB
