Re: main clearances and end play???? [Re: Bob_Coomer] #816896
09/30/10 02:15 PM
09/30/10 02:15 PM
Communist New York State, Comi...
W
We The People Offline OP
W
Thanks Bob, I checked it with mikes and a dial bore gauge. The crank was extremely close on all the mains, I will check the roundness tomorrow.
Heres a question for you... if I'm looking for .001" more clearance on three mains. wouldnt it be simpler and more efficient time wise to just get 3 x bearing with .001 more clearance? How far off could the main bore be to clamp .001 too tight?
I deffinately agree that the mains and rods need to be perfect, and I am attemting to get them there.
Re: main clearances and end play???? [Re: We The People] #816897
09/30/10 02:39 PM
09/30/10 02:39 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Good question, the + bearings might work, but in my case, and probably yours the whole main bore wasnt consistent. Im not going to say it wont work, but if the bore is egg shaped its just not a good fix. If the bore is egg shaped, you add the over sized bearings while it might give you some extra clearance, when you torque the cap down that saddle is now egg shaped also.
Talk to your machinist, and ask what it would cost to fix it properly. Heck a set of main bearings is $100 now. If I could have the block lined honed for a hair more that would be better. Talk to him get his take on what should be done.
Re: main clearances and end play???? [Re: Bob_Coomer] #816898
09/30/10 03:59 PM
09/30/10 03:59 PM
W
W
thanks again Bob...good answer. gives me a bit more to think about. I may end up driving to syracuse with it yet.
Re: main clearances and end play???? [Re: We The People] #816899
10/01/10 12:02 PM
10/01/10 12:02 PM
W
W
BOB COOMER wins the why are my clearances messed up contest!!!!!!!!!
I checked the main bores today, and found they were .0025" fatter at the parting line. I only check#1... cause why bother continuing?
It didnt occur to me to to start there, cause I had the block line bored for the caps before...or so I thought. remember what I posted about no good shops around here...
Re: main clearances and end play???? [Re: We The People] #816900
10/01/10 12:10 PM
10/01/10 12:10 PM
NC
440Jim Offline
440Jim  Offline
NC
Good start. Was that just the cap and block or was that with the bearing in it? All bearings will be looser at the parting line.
What was the actual cap and block bore dimension?
Re: main clearances and end play???? [Re: 440Jim] #816901
10/01/10 12:53 PM
10/01/10 12:53 PM
W
W
just the empty bores. I dont have an inside mike, so I set the outside mike to the spec 2.9425", and zeroed the dialbore gauge. this would show me any out of round condition. and it did.
the vertical measurement was a half thou. big 2.9430" which is right at the big side of the range posted above. but like I said it was just showing the diff from the zeroing mike so that may not be the actual size.
I also double checked with a telescoping gauge, from vertical to parting line...it too showed the diff in the 90*.
Looks like I will be dragging it to Syracuse, to see Todd, and get some machining..
Re: main clearances and end play???? [Re: We The People] #816902
10/01/10 01:30 PM
10/01/10 01:30 PM
Good find
Re: main clearances and end play???? [Re: Cab_Burge] #816903
10/01/10 01:53 PM
10/01/10 01:53 PM
W
W
Thanks Cab, I finally figured it out...
Re: main clearances and end play???? *DELETED* [Re: We The People] #816904
10/01/10 08:41 PM
10/01/10 08:41 PM
Delray beach, Florida
P
Performance Only Offline
P
Post deleted by Performance Only
machine shop owner and engine builder
Re: main clearances and end play???? [Re: Performance Only] #816905
10/01/10 08:43 PM
10/01/10 08:43 PM
P
P
just a little information for you. if the bores at the parting line are .0025 big as you describe, you only have three choices.
1, either bore the blocks mating surface to close that gap, (which would take a lot of work) cut the caps and align bore it again,
2, cut the caps and bore/ hone for proper vertical sizing and don't worry about the out of round.
3, toss that block and start with a better one.
align boring a block does not make the parting line wide, or bigger. align honing almost always will. boring a block doesn't always look as pretty because it'll leave a shadow where it doesn't cut. a hone will hit the wide area and make them even wider.
from what i've seen, most factory blocks are already wide at the parting line from the factory, but typically only .0002-.0005, not .0025
take it to Todd and let him decide the best course of action.
Re: main clearances and end play???? [Re: Performance Only] #816906
10/02/10 05:53 PM
10/02/10 05:53 PM
W
W
I saw King Bearings make Oversized OD main bearings for some Chevys. Are there any floating around for mopars, they would be useful in this situation.
Re: main clearances and end play???? [Re: We The People] #816907
11/23/10 12:44 AM
11/23/10 12:44 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Just bumping this to the top because I think its some great info for some current posts and for any other review, mike
Re: main clearances and end play???? [Re: 70Cuda383] #816908
11/23/10 10:13 AM
11/23/10 10:13 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
with tighter clearances, couldn't you just run a lighter weight/synthetic oil and save HP by not turning as much on the oil pump?
I run my stocker engines quite tight because I use nothing but zero weight oil. I would not suggest that pratice for a bracket engine but your theory is right.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
