main clearances and end play???? ..AND THE WINNER IS!!
#816876
09/28/10 08:02 PM
09/28/10 08:02 PM
Posts: 190 Communist New York State, Comi...
We The People
Just finished mocking up, checking clearances on my new eagle 4.15 crank that came in my Mancini 493 kit. after switching shells around from saddle to saddle this is the best I could come up with for clearances. #1 .0025 #2 .0025 #3 .0025 #4 .0035 #5 .0035 the end play came out at .004 What do you all think? should I get 3 half shells with .001 extra clearance or will .0025 be all right? is that end play right for that radiused crank? thanks guys
Re: main clearances and end play????
[Re: Monte_Smith]
#816878
09/28/10 11:23 PM
09/28/10 11:23 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I know some people like more clearence on a race motor but my race only sb 416 has been very happy at .0025 on all 5 mains and the end play is at .006
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: We The People]
#816881
09/29/10 03:16 AM
09/29/10 03:16 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
with tighter clearances, couldn't you just run a lighter weight/synthetic oil and save HP by not turning as much on the oil pump?
**Photobucket sucks**
[Re: We The People]
#816882
09/29/10 10:16 AM
09/29/10 10:16 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Yes it is a race engine... but not extreme, stock block studded top and bottom, aluminum caps s/r heads. most likely about 650 hp.... no dynos around here.
What size are the holes in your main caps , mainly the #3 cap? With studs and stock caps you have to ream the holes to the next size up , not sure what's required with alum. caps .
[Re: We The People]
#816884
09/29/10 10:55 AM
09/29/10 10:55 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
[Re: We The People]
#816888
09/29/10 11:38 AM
09/29/10 11:38 AM
JohnRR
U.S.S.A.
The main bores were line honed for the aluminum caps/studs. and the engine was run with a factory .020 under steel crank, that crank had no main bearing issues....all though I dont know what the main clearances were in that setup. thats why I believe the issue is with the shells , I pretty sure the clevite 77 series I am using can be ordered + or - .001" and that would set it up with .0035 all around. that seems like the easiest solution. but I'm still looking for ideas.
Not asking about the main bore sizes but the holes that the studs go thru , if they are too tight on the studs you can't set the thrust properly.
[Re: We The People]
#816890
09/29/10 12:31 PM
09/29/10 12:31 PM
JohnRR
U.S.S.A.
I've never noticed them being snug, they slide right down, then I just tap them down in the block with a small plastic hammer. they are Muscle Motors caps made in '2000.
They won't be snug , but they might limit front to back motion if too tight . But MM caps should have the larger holes .
[Re: We The People]
#816893
09/30/10 01:10 PM
09/30/10 01:10 PM
Posts: 16,925 NC
440Jim
NC
What is the main bore supposed to be?
From Moparts.com, a member posted the main bearing cap dimensions:
B - 2.8175 - 2.8180 RB - 2.9425 - 2.9430
[Re: 440Jim]
#816894
09/30/10 01:29 PM
09/30/10 01:29 PM
We The People
Thanks for the info guys. I'm going to recheck them tomorrow, along with the runout, and main bore. when I did them the other day, my father opened the big over head door, and there was a big difference in the cool insulated garage air and the weird warm storm front that was rolling through. the block started to collect condensation during the process. not sure if it affected it or not, cause we kept rechecking and getting the same numbers over a couple hours. by the end the block had warmed a bit and was staying dry. today I seated the thrust bearing a bit harder and I got .005" Anyway I decided to go through a good recheck before making a decision. better to spend my free time and know for sure than waste cash blindly.
[Re: 440Jim]
#816895
09/30/10 01:31 PM
09/30/10 01:31 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
You need to get it checked, how are you checking it? Its border line now and allows NO room for margin if the crank is out any at all. I really like to know what each main bore, and crank journal measures though. Thing is if your already boarder line tight, you cant afford any thing tighter, and I highly doubt the crank is perfect. If its out of round any could be a big problem. Thats why I measure my main bores with a dial bore gauge, and measure the crank. I can then hone the block to correct and order the correct bearings is the last thing. This doesnt cost much more money either. Its exactly what I done with the Hemi. The #3 main bore was .001 tight, and #5 half a thou also. I honed the mains, and ordered the HXN bearings etc. Out of all the things that really need to be done correctly, the crank, mains, and rod sizing needs to be perfect or real close in my race engines. I set my rods and mains .003-.0035, .003 being minimal, but I know a few engine builder that like them at .0025 also... .004 thrust is tight too. IMO if you could gain another .001 some how that would be great. .006-.008 is idea IMO.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
