Head bolts #816829
09/28/10 06:44 PM
09/28/10 06:44 PM
Kent,OH
B&E Offline OP
B&E  Offline OP
Kent,OH
I am rebuilding a 383 that had never been apart.Do I need to replace the head bolts? The rebuild will be stock and the car is just a cruiser if that matters.
68 Super Bee Black,White stripe
Re: Head bolts [Re: B&E] #816830
09/28/10 06:51 PM
09/28/10 06:51 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'd use them again. They rarely break or fail to clamp well.
Re: Head bolts [Re: buildanother] #816831
09/28/10 08:01 PM
09/28/10 08:01 PM
What buildanother said, light hand wire brush em clean/solvent clean/blow dry/like any part a visual check but rarely a prob there. I lube the threads w 30 wt eng oil then blow it off w shop air. Leaves a VERY LIGHT film of lube
