what will it run 418 stroker?UPDATED RESULTS!!
#816776
09/28/10 05:48 PM
09/28/10 05:48 PM
Posts: 1,365 elmira ny
hp340nos
elmira ny
88 dakota 3340# street/strip weight bias is 56%front,44%rear 340 stroker 418cid, 9.7 compression ohio 4" crankshaft,scat i-beam rods, diamond pistons(balanced).cam is solid roller herbert .246/.254@.050,.585in/.600 ex,lash set at .018in/.020ex,108 lobe seperation, installed at 103.5*. cast x-heads full port/polish, w/manley 2.055/1.625,db springs to match the cam [Email]etc.flowed.270@.600in[/Email],.170ex@.600 weiand x-celerator intake gasket matched harlans sharp 1.5 rockers/shafts/holddowns manley pushrods stock, rebuilt holley 750 db pumper 6.5 pv, jets are 73f/81r,squirters are 31/31. msd 6al box,mp distributor tranny is 727 with reverse pattern,low band apply good clutches/kolenes ,ptc 10" converter flashes 4100 rpm, 8 3/4 rear sure-grip with 3.91 gears. 295/65-15 mickey thompson drag radial stock shocks front/rear caltrac style bars heim joint ends truck has been a best of [Email]7.54@90[/Email] mph with 1.63 60ft, with a mild 318 and a shot of nitrous.any ideas were i might be when i get it tuned in?also what rpm should i shift at?im heading to the track this friday night.thanks mike
Re: what will it run 418 stroker ?1/8 mile
[Re: FlyFish]
#816782
09/28/10 08:04 PM
09/28/10 08:04 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
7.40 with the 750. 7.20's with a 950 jetted right.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: hp340nos]
#816790
09/30/10 12:50 AM
09/30/10 12:50 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
needs more gear for eigth mile. i assume its street driven..?
with a 430 gear id say 680s i am gonna say 7.0 as it its.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: 9 Sec Phill]
#816793
09/30/10 09:36 AM
09/30/10 09:36 AM
Posts: 2,648 GA
Boosted
GA
7.25 tuned.. Off the trailer 7.50's
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: all spooled up]
#816796
10/02/10 12:16 AM
10/02/10 12:16 AM
hp340nos
elmira ny
i ran a best of 7.311@94.73 ,60FT was 1.62,launching at 2000,shift at 6000.i also ran 7.35@94.31 ,7.32@94.3 ,7.315@94.55 i dropped the tire pressure down to 18 psi and ran it just like i do on the street,9sec phil was down there also,gave me some tips.thanks phil,
[Re: hp340nos]
#816797
10/02/10 10:12 AM
10/02/10 10:12 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Very nice Mike. ...and you got to drive it home.....sweet. For the record, the track is up on a mountain, he will/would run at least a tenth faster " down off the mountain". A little tuning, some more carb and I bet its 11.10's. Not bad for a truck with factory iron heads. The 60's definately hurt the overall ET, but its not a dedicated race vehicle either. Good job first time out.
RIP Monte Smith
[Re: CompWedgeEngines]
#816798
10/02/10 10:31 AM
10/02/10 10:31 AM
ChrgrCuda
Texas, USA
Great results. Anytime you can drive it to the track and run those kind of numbers, you should be very very happy. Great job!
