88 dakota 3340# street/strip
weight bias is 56%front,44%rear
340 stroker 418cid, 9.7 compression
ohio 4" crankshaft,scat i-beam rods, diamond pistons(balanced).cam is solid roller herbert .246/.254@.050,.585in/.600 ex,lash set at .018in/.020ex,108 lobe seperation, installed at 103.5*.
cast x-heads full port/polish, w/manley 2.055/1.625,db springs to match the cam [Email]etc.flowed.270@.600in[/Email],.170ex@.600
weiand x-celerator intake gasket matched
harlans sharp 1.5 rockers/shafts/holddowns
manley pushrods
stock, rebuilt holley 750 db pumper 6.5 pv, jets are 73f/81r,squirters are 31/31.
msd 6al box,mp distributor
tranny is 727 with reverse pattern,low band apply good clutches/kolenes ,ptc 10" converter flashes 4100 rpm,
8 3/4 rear sure-grip with 3.91 gears.
295/65-15 mickey thompson drag radial
stock shocks front/rear
caltrac style bars heim joint ends
truck has been a best of [Email]7.54@90[/Email] mph with 1.63 60ft, with a mild 318 and a shot of nitrous.any ideas were i might be when i get it tuned in?also what rpm should i shift at?im heading to the track this friday night.thanks mike
