2000 Neon lost compression/2.0 HELP!!!!! #816649
09/28/10 12:37 PM
09/28/10 12:37 PM
DELAWARE
bee71mopar Offline OP
DELAWARE
Hello I have this 2000 Neon/2.0, the #3 cylinder has low compression compared to the rest..getting a code also..need to run through inspection by the end of the month yea 2 more days..
the timing belt and water pump where replaced,I did the work and the timing belt was not broke completely just the teeth,and I have been driving it like this for almost a year now, but inspection time...
Any suggestions on how to get the compression up or do I have to pull the head...
Re: 2000 Neon lost compression/2.0 HELP!!!!! [Re: bee71mopar] #816650
09/28/10 12:50 PM
09/28/10 12:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You probably bent a valve when the belt went south. You will end up having to pull the head at least. Driving it that way for as long as you have didn't help it any and may end up costing you a bunch depending on any damage done to the head.
Re: 2000 Neon lost compression/2.0 HELP!!!!! [Re: stumpy] #816651
09/28/10 01:05 PM
09/28/10 01:05 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Probably a bent valve but you could run a wet test on that cylinder to verify if it's a ring issue or not.
How many miles on that timing belt just out of curiosity ?
Ron
Re: 2000 Neon lost compression/2.0 HELP!!!!! [Re: bee71mopar] #816652
09/28/10 05:27 PM
09/28/10 05:27 PM
DELAWARE
DELAWARE
There's about 6000 miles on the timing belt
Re: 2000 Neon lost compression/2.0 HELP!!!!! [Re: bee71mopar] #816653
09/28/10 08:49 PM
09/28/10 08:49 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I always apply 50lbs or so air pressure to the affected cylinder with the piston at TDC on the compression stroke and listen for the escaping air. It will tell you what to look for when you pop the head, which will probably be necessary.
Master, again and still
Re: 2000 Neon lost compression/2.0 HELP!!!!! [Re: DaveRS23] #816654
09/28/10 08:56 PM
09/28/10 08:56 PM
DELAWARE
DELAWARE
Thanks I'll try that..
