Do keys for 2005 Neons have any kind of chip in them? #816627
09/28/10 10:29 AM
09/28/10 10:29 AM
RI Deep in the rust belt
chargervert Offline OP
A freind of mine has a 2005 Dodge Neon. The dealership wants $60.00 for a Key? I looked at the key,and I do not see any evidence of it having any chip. Are they pulling his chain on this? It looks no different than my ram key,except for the plastic molded dodge logo peice.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Do keys for 2005 Neons have any kind of chip in them? [Re: chargervert] #816628
09/28/10 10:37 AM
09/28/10 10:37 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
if it's black plastic, I think it's a regular key
if it's grey plastic it's a chip key - and requires programming, thus the expense
Re: Do keys for 2005 Neons have any kind of chip in them? [Re: gtx6970] #816629
09/28/10 10:40 AM
09/28/10 10:40 AM
Yeah it's the grey one. Thanks Bill
Re: Do keys for 2005 Neons have any kind of chip in them? [Re: gtx6970] #816630
09/28/10 10:42 AM
09/28/10 10:42 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Correct.
Earning every penny of that moderator paycheck.
DBAP
Re: Do keys for 2005 Neons have any kind of chip in them? [Re: chargervert] #816631
09/28/10 10:48 AM
09/28/10 10:48 AM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
Look up on the web how to program it. Dodge may be different from gm but I looked it up for my wives olds and to program it was simple. I don't remember exactly but it was something like turn the ignition on and off a couple times leave ign on open glove box open driver door turn ign off then back on. No special tools needed.
Re: Do keys for 2005 Neons have any kind of chip in them? [Re: Boise Chall] #816632
09/28/10 12:15 PM
09/28/10 12:15 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Has skim keys. Dealer programs in the key with the DRBIII. Also has a skim code the dealer gets from dealer connect to gain access to program. Good idea to have all of your keys with you when this is done to make sure they work.
Re: Do keys for 2005 Neons have any kind of chip in them? [Re: Todd] #816633
09/28/10 01:05 PM
09/28/10 01:05 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Hey Pete..
Kim's '06 Durango has to have the very same thing done to it, Reprogrammed. It's been the root cause of all our woes.. It doesn't even unlock the doors any more. Service writer states it's a simple procedure. I just wish they would have had done this in the very beginning. This is my 3rd trip back to the dealership for the very same original problem.
Good luck.
Troy
Houston Mopar Connection Club
Re: Do keys for 2005 Neons have any kind of chip in them? [Re: hemi68charger] #816634
09/28/10 05:36 PM
09/28/10 05:36 PM
Troy,I hope you get Kim's truck fixed. Thanks everyone for the info. Troy,i'll send you a PM tomorrow on those other parts. Pete
Re: Do keys for 2005 Neons have any kind of chip in them? [Re: chargervert] #816635
09/28/10 08:23 PM
09/28/10 08:23 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
We deal with this all the time. He may want to try this; Have a couple of keys cut at the local hardware store for a few bucks each. Then remove the lower column cover and tape or glue the original key to it where the car will run. Sometimes it seems that the key can be just about anywhere under the key switch and sometimes it wants the key in a particular spot.
Anyway, you can have as many keys as you want cut anywhere you want and they will work.
Master, again and still
