73 Dodge power wagon gear ratio #816429
09/27/10 11:54 PM
09/27/10 11:54 PM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
Can anybody give me an idea of what gear ratio a 73 Power Wagon 318 auto 1/2 ton 4x4 8-3/4 with locking hubs should have. I know it's impossible to know for sure with the info I gave but does anybody have a good guess. A guy is selling the rear for cheap but doesn't know the ratio he thinks it's a 3:55 It's about 25 miles away and I don't want to go after it if it's a highway ratio. I just plan to use the center chunk for my Roadrunner.
Re: 73 Dodge power wagon gear ratio [Re: Boise Chall] #816430
09/28/10 12:12 AM
09/28/10 12:12 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I bought a '74 W100 new, 360, auto, 3.55 gear. You may want to check for a Sure Grip, mine had an open diff, SG was opt. Don't recall if it was the std gear or optional.
Sold it in '77, only Mopar I sold that I wish I had back.
Re: 73 Dodge power wagon gear ratio [Re: B5 Bee] #816431
09/28/10 12:39 AM
09/28/10 12:39 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
3.55 or 3.91s
I am truckless..
Re: 73 Dodge power wagon gear ratio [Re: 340SHORTY] #816432
09/28/10 02:27 AM
09/28/10 02:27 AM
hooziewhatsit Offline
It should have some tags on it that identify the ratio, or he can jack one side up, then spin the driveshaft and figure out the ratio from there. If he has one tire off the ground, he'll need to halve the tire rotation count.
http://www.getahelmet.com/jeeps/tech/findratio/
Re: 73 Dodge power wagon gear ratio [Re: hooziewhatsit] #816433
09/28/10 10:40 AM
09/28/10 10:40 AM
Boise Idaho
Boise Idaho
will this chunk fit in my 69 B-body housing without any major hassle? Thank you for the help.
Re: 73 Dodge power wagon gear ratio [Re: Boise Chall] #816434
09/28/10 10:43 AM
09/28/10 10:43 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Yes an 8 3/4 chunk is a 8 3/4 chunk.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 73 Dodge power wagon gear ratio [Re: HemiRick] #816435
09/28/10 10:49 AM
09/28/10 10:49 AM
Boise Idaho
Boise Idaho
Thank You
Re: 73 Dodge power wagon gear ratio [Re: Boise Chall] #816436
09/28/10 10:59 AM
09/28/10 10:59 AM
scratchnfotraction Offline
the axles are most likly are candates for cut and respline
they may have the larger flange with 5 on 5.5 wbp or the 5 on 4.5 wbp
check the axles to see if you have 28" before it tappers down,those could be cut for A-body specs
the housing is same as a c-body,just spring over axle
my 3.91 sg was from a 72 4x4
my 3.55 sg was from a 74 van
my 3.23 open was from a 67 polara
they will swap right in
what gear/chunk do you have now?
Re: 73 Dodge power wagon gear ratio [Re: scratchnfotraction] #816437
09/28/10 11:29 PM
09/28/10 11:29 PM
Boise Idaho
Boise Idaho
These are for my 73 Roadrunner I don't have a center chunk at all I just have a 69 B-body housing with axles and backing plates.
