73-74 Cuda rear bumper #816389
09/27/10 11:30 PM
09/27/10 11:30 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
I dont like the "filler" piece on these cars rear bumper. What would have to be done to put a '72 bumper on? Would it just bolt up in place and eliminate the filler piece?
Re: 73-74 Cuda rear bumper [Re: DaKuda] #816390
09/28/10 07:35 AM
09/28/10 07:35 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You need to either modify the bumper braces to recess the bumper, or use 70-2 bumper braces and bumper to acheive the look your after,...they are avaliable aftermarket if desired, or used...
Re: 73-74 Cuda rear bumper [Re: DaKuda] #816391
09/28/10 07:36 AM
09/28/10 07:36 AM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
You need 70-72 bumper brackets and bumper. The 73-74 bumper bolts to the reinforcing bracket so the spacing on the holes are different. 70-71 bumpers typically do not have slots for a jack where as the 72 does, although I think the slots did show up in late production 71s.
Re: 73-74 Cuda rear bumper [Re: N9671X2] #816392
09/28/10 07:39 AM
09/28/10 07:39 AM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
Forgot to mention you will also need 70-72 bumper guards and plastict filler behind them to valance.
Re: 73-74 Cuda rear bumper [Re: N9671X2] #816393
09/28/10 08:20 AM
09/28/10 08:20 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Thanks guys.
Re: 73-74 Cuda rear bumper [Re: DaKuda] #816394
09/28/10 09:53 AM
09/28/10 09:53 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If you are going to move the rear bumper in, I'd move the front in as well. There are a few square holes in the front bumper brackets just ahead of the stock mounting holes. You can drill out those square holes to 5/8" They become your new mounting holes.
