paint polish recommendations? #816037
09/27/10 05:53 PM
09/27/10 05:53 PM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
After all of the work on the guts of my car, I feel the outside deserves some attention as well.
It was painted with single stage urethane and it has dulled and faded a lot especially on the roof and other top sides. Problem is a while back I had some issues due to tree sap and had to do a lot of sanding and cutting with 3M finesse it to get it shiny again back then. But it left the paint a little thin in places, so I am hoping to find something less abrasive than the Finesse It that I can use with a rotary buffer and foam pad.
Is the 3M "Perfect It" series a finer material? Or has anyone else had good results with another product?
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: paint polish recommendations? [Re: Michael Ecks] #816038
09/27/10 07:58 PM
09/27/10 07:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Finesse-It or Perfect-It are the 2 things I use; actually there are no abrasives in either one. Where the paint is thin you might try a clay bar to clean it, and then wax over it.
I don't use cleaner/waxes, just straight carnauba.
Re: paint polish recommendations? [Re: topside] #816039
09/27/10 08:43 PM
09/27/10 08:43 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
If its thin and you break through there's no good way to fix it but repainting it.
Re: paint polish recommendations? [Re: Michael Ecks] #816040
09/27/10 11:47 PM
09/27/10 11:47 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
I've used both for many years and find that Mequiars is a better, if not more expensive, paint polishing product. I would use the Diamond Cut Compound 2.0 with a wool pad to start with. Then go over it with No. 7 polish and a foam pad.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
