Re: SuperStock Springs Shocks
[Re: roadhazard]
#815750
09/27/10 03:26 PM
09/27/10 03:26 PM
Posts: 2,826 NY usa
540challenger
NY usa
002/003 springs with QA-1's single adjustable with CE 90/10's up front
Best 60' @ 1.389, average 60' @ 1.40's 3325# with driver 6.434 1/8th @ 105.50 mph, 1,000' @ 8.460 I put them on, set @ #6 position and havn't had the opportunity to make any adjustments yet FWIW
How well does the QA-1 shocks fit in the shock crossmember I had 2 E-bodies and 1 B-body were i had to make spacer"1/2 on each side" because they bushing was too small and the shock was sliding around??
[Re: DusterKid]
#815751
09/27/10 06:17 PM
09/27/10 06:17 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
What shocks are you guys using with super stock springs. I have a 73 duster weighs 3050 w/out driver so roughly 3210 w/driver, 360, 727, dana 60 with a 1.63 60' times. The springs have been relocted 3". I have comp engineering 3 way adjustables up front set on 90/10, but just a basic shock in the rear, am looking to upgrading to a better shock.
i just switched from Ram truck shocks to Rancho 9 ways. I will give you some results in about 5 days
this is a dart with SS springs , best 60' last spring was 1.44 .
[Re: 540challenger]
#815753
09/27/10 07:14 PM
09/27/10 07:14 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Never noticed any fitment issues on my A-Body
[Re: roadhazard]
#815754
09/27/10 07:21 PM
09/27/10 07:21 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Had so good of luck with the CE 3 ways all around i never got rid of them with the 002/003 leafs i had.
Et and 60 foot with them in my signature.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
