SuperStock Springs Shocks #815747
09/27/10 01:15 PM
09/27/10 01:15 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
What shocks are you guys using with super stock springs. I have a 73 duster weighs 3050 w/out driver so roughly 3210 w/driver, 360, 727, dana 60 with a 1.63 60' times. The springs have been relocted 3". I have comp engineering 3 way adjustables up front set on 90/10, but just a basic shock in the rear, am looking to upgrading to a better shock.
Re: SuperStock Springs Shocks [Re: DusterKid] #815748
09/27/10 02:01 PM
09/27/10 02:01 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Garrett..I've had real good results using the 9-way adjustable Rancho's on my '69' 440 GTX. I use the 002-003 Hemi Dart/Barracuda SS springs. Also,I would strongly advise using the Calvert Racing 90/10 front shocks for excellent weight transfer..if you don't plan on doing much road racing out on the streets! My HEAVY(3740)street car runs 1.54-1.60 short times..with slicks! RandyB
Re: SuperStock Springs Shocks [Re: Labratt] #815749
09/27/10 03:13 PM
09/27/10 03:13 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
002/003 springs with QA-1's single adjustable with
CE 90/10's up front
Best 60' @ 1.389, average 60' @ 1.40's
3325# with driver 6.434 1/8th @ 105.50 mph, 1,000' @ 8.460
I put them on, set @ #6 position and havn't had the opportunity to make any adjustments yet FWIW
Re: SuperStock Springs Shocks [Re: roadhazard] #815750
09/27/10 03:26 PM
09/27/10 03:26 PM
NY usa
540challenger Offline
NY usa
CE 90/10's up front
How well does the QA-1 shocks fit in the shock crossmember I had 2 E-bodies and 1 B-body were i had to make spacer"1/2 on each side" because they bushing was too small and the shock was sliding around??
Re: SuperStock Springs Shocks [Re: DusterKid] #815751
09/27/10 06:17 PM
09/27/10 06:17 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i just switched from Ram truck shocks to Rancho 9 ways. I will give you some results in about 5 days
this is a dart with SS springs , best 60' last spring was 1.44 .
Re: SuperStock Springs Shocks [Re: 493_DART] #815752
09/27/10 07:03 PM
09/27/10 07:03 PM
Keymar, MD
Keymar, MD
Which part # Rancho are you guys using?
Re: SuperStock Springs Shocks [Re: 540challenger] #815753
09/27/10 07:14 PM
09/27/10 07:14 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
CE 90/10's up front
Never noticed any fitment issues on my A-Body
Re: SuperStock Springs Shocks [Re: roadhazard] #815754
09/27/10 07:21 PM
09/27/10 07:21 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Had so good of luck with the CE 3 ways all around i never got rid of them with the 002/003 leafs i had.
Et and 60 foot with them in my signature.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
