Thoughts on this... #815679
09/27/10 12:38 PM
09/27/10 12:38 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Ok, later today I'll post up pictures of my dyno run, but I would be interested in hearing all of your guy's theories on why this happened?
My 440 made great power up until 5000 or so where the power curve really leveled off, and maintained up too 6000. I'm just kind of suprised based on the characteristics of the cam that it leveled off and didn't continue to build
I updated the fuel system went to a big carter street/strip pump
Cam XE 268
440source aluminum heads
770 street avenger carb
Holley Dominator intake
shorty style hedman 13/4 headers
Mike
1969 Dodge Dart Swinger
Re: Thoughts on this... [Re: MikeyT] #815680
09/27/10 12:50 PM
09/27/10 12:50 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
doesn't really surprise me. It isn't much of a cam for high RPM's. I would have thought 5500-5800 peak though.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Thoughts on this... [Re: MoparforLife] #815681
09/27/10 01:41 PM
09/27/10 01:41 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What were the hp and torque #'s ?? Ron
Re: Thoughts on this... [Re: MikeyT] #815682
09/27/10 02:20 PM
09/27/10 02:20 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
if you showed power up to 6,000, thats about right..
what was the cam installed at...shows its a 110* LSA..
maybe advance the cam 4* for more upstairs
Re: Thoughts on this... [Re: smokinwoody] #815683
09/27/10 07:09 PM
09/27/10 07:09 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Here is the dyno sheet.
The colored Blue line is Torque and the Colored redline is HP, after the first run. The dotted line that follows closely is the new run after headers uncorked.
Top HP was 327 and 421 Ft/LBS after uncorking the headers.
Here is the run on the dyno! I'msorry this things me giggle everytime I hear it.
http://www.youtube.com/watch?v=Oc-SlHqFKqM
Mike
PS I know its not a big dog, but it has me real excited!
Re: Thoughts on this... [Re: MikeyT] #815684
09/27/10 09:27 PM
09/27/10 09:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Smallish cam, small carb and small headers... its about
right
Re: Thoughts on this... [Re: MR_P_BODY] #815685
09/27/10 09:30 PM
09/27/10 09:30 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
right
Peak at or just above 5k, and falling off by 6k seems right to me for that combo.
Re: Thoughts on this... [Re: MikeyT] #815686
09/27/10 10:22 PM
09/27/10 10:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also did you try to lean out the carb some... looks
a little fat
Re: Thoughts on this... [Re: MR_P_BODY] #815687
09/27/10 10:41 PM
09/27/10 10:41 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Cool, thanks guys. Yeah, we kept it a little bit fatter on the A/F
Mike
Re: Thoughts on this... [Re: MikeyT] #815688
09/27/10 11:55 PM
09/27/10 11:55 PM
BB Mopar wedge motors need better heads to make more power and to extend the power range, both torque and horsepower I would (and do)lean it down for more power
Re: Thoughts on this... [Re: Cab_Burge] #815689
09/28/10 12:28 AM
09/28/10 12:28 AM
Communist New York State, Comi...
W
We The People Offline
W
that sounds good....and that is right in the ball park for your parts.
