69 B-Body steering column #815537
09/27/10 08:58 AM
09/27/10 08:58 AM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
his guys whats involved to replace the lower bearing , what needs to de done ? can you take the coupler off that way or have to dismantle the whole lot !
thanks for any advice
Re: 69 B-Body steering column [Re: A47] #815538
09/27/10 09:11 AM
09/27/10 09:11 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The only way to do it without dis-assembling the column is take the lower coupler of the shaft and remove the cross pin from the main shaft. Then you can take the lower bearing support out.
Provided it's a floor shift. Column shift cars the shift tube has to come out which requires complete dis-assembly
Re: 69 B-Body steering column [Re: gtx6970] #815539
09/27/10 12:00 PM
09/27/10 12:00 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
thank you for the quick reply !! really appreciated
yes floor shift , !! how difficult is the cross pin to get out ? would it be a press fit or ???
