Paint job or vinyl top. What would you do first? #815460
09/26/10 11:49 PM
09/26/10 11:49 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
With the old vinyl top still being on the car, do you think it makes more sense to paint the car first and then install a new vinyl top or install the top first and then paint the car?
Re: Paint job or vinyl top. What would you do first? [Re: 6PAX] #815461
09/26/10 11:56 PM
09/26/10 11:56 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
What would your do;
single choice
Votes accepted starting: 09/26/10 10:56 PM
You must vote before you can view the results of this poll.
Re: Paint job or vinyl top. What would you do first? [Re: Alaskan_TA] #815462
09/27/10 12:04 AM
09/27/10 12:04 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Top goes on after paint & if you can't afford to do both just strip the top & have the top painted for now & you can apply a top at a later date....
Re: Paint job or vinyl top. What would you do first? [Re: 1_WILD_RT] #815463
09/27/10 03:09 AM
09/27/10 03:09 AM
USA
rftroy Offline
rftroy  Offline
USA
The tops of vinyl top cars got a very thin layer of primer, which was ineffective in preventing rust for more than a couple of years. After 40, the top is definitely surface rusted, and you will be lucky if you don't have to do some metal patching, especially around the rear window bottom.
Also, you should pull the headline and see how bad the rust is on the underside of the roof, as well. Clean it, prep and paint also.
Don't just use primer, even an epoxy primer; cover the primer with paint.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Paint job or vinyl top. What would you do first? [Re: rftroy] #815464
09/27/10 03:18 AM
09/27/10 03:18 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
You'll also have to do something with the seam where the roof connects to the C plliar. Painted cars were leaded in, vinyl top cars were only caulked. Caulking doesn't keep the water(rust) out like lead.
Re: Paint job or vinyl top. What would you do first? [Re: B5 Bee] #815465
09/27/10 01:29 PM
09/27/10 01:29 PM
NORTHERN IL
MOPAR-OVERLOAD Offline
NORTHERN IL
DON'T PAINT AND THEN DO ROOF, THE ROOF WILL NEED WORK ALMOST 99% OF THE TIME. YOU MAY BE SURPRISED TO FIND OUT YOU'LL NEED TO REPLACE IT. CHECK INSIDE AND OUT. YOU DON'T WANT TO PAINT THEN FIND OUT YOU NEED TO MAKE REPAIRS. HOPE YOUR LUCKY!
Re: Paint job or vinyl top. What would you do first? [Re: 6PAX] #815466
09/27/10 08:50 PM
09/27/10 08:50 PM
Jacksonville Florida
elitecustombody Offline
Where is the option of leaving the top off? It's a rust trap keep it off
Re: Paint job or vinyl top. What would you do first? [Re: elitecustombody] #815467
09/27/10 09:22 PM
09/27/10 09:22 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I would paint the entire car first and then reinstall a new top over a painted, not primered, roof. If the car is a weekend warrior that stays dry then I don't think having a vinyl top is anything to worry about. If your daily driving it and it sits outside with 4" of snow on it half the year then leave it off.
I found zero rust under my original 1970 top, even the window channels were spotless. After seeing photos of heavily rusty roofs under vinyl top cars I know I lucked out big time!
Re: Paint job or vinyl top. What would you do first? [Re: Neil] #815468
09/28/10 12:51 PM
09/28/10 12:51 PM
Mopar World Headquarters
P1970HeMICuDA Offline
Paint roof, blend into tops of qtrs, dutchman, fenders, etc.
Install vinyl top, front and rear glass and moldings.
Mask top of car, any moldings, sand and prep around edges.
Paint rest of car.
Remove masking,
This way lessens chance of damage of working around a freshly painted car.
