426 hemi fuel line/ distributor clearance problem #815289
09/26/10 08:51 PM
09/26/10 08:51 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Putting the distributor in my street hemi (67) and Im having a problem with the distributor cap interfering with the fuel line that exits the left side of the "T" fitting, which feeds the front carb. Anyone run into this problem?? Almost looks like the support bracket that attaches to the top coil bolt and goes to the right side of the "T" puts that fitting too far to the left. Appreciate some help or pictures
THanks
Re: 426 hemi fuel line/ distributor clearance problem [Re: hemi67] #815290
09/26/10 09:15 PM
09/26/10 09:15 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Common problem with reproduction fuel lines, they are way off sometimes and need to be tweaked pretty good to fit. So far I have found that none of the reproductions out there match originals perfectly. Here is an original set installed on a 67 Hemi Belvedere.
Re: 426 hemi fuel line/ distributor clearance problem [Re: ScottSmith_Harms] #815291
09/26/10 09:16 PM
09/26/10 09:16 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
same car, different angle
Re: 426 hemi fuel line/ distributor clearance problem [Re: ScottSmith_Harms] #815292
09/26/10 09:17 PM
09/26/10 09:17 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's a reproduction set on a different 67 Belvedere
Re: 426 hemi fuel line/ distributor clearance problem [Re: ScottSmith_Harms] #815293
09/26/10 09:18 PM
09/26/10 09:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
same car
Re: 426 hemi fuel line/ distributor clearance problem [Re: ScottSmith_Harms] #815294
09/26/10 09:19 PM
09/26/10 09:19 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
another
Re: 426 hemi fuel line/ distributor clearance problem [Re: ScottSmith_Harms] #815295
09/26/10 09:20 PM
09/26/10 09:20 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
He was in a hurry to install these getting ready for a show, they are not installed propely, bracket is bent, routing, etc. but regardless they are reproductions and were off by a mile.
Re: 426 hemi fuel line/ distributor clearance problem [Re: ScottSmith_Harms] #815296
09/26/10 10:00 PM
09/26/10 10:00 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Scott, thank you for the pictures. They are a big help.
