Thread lock on axle studs? #814847
09/26/10 11:26 AM
09/26/10 11:26 AM
Lees Summit, MO
BrianT Offline OP
BrianT  Offline OP
Lees Summit, MO
I'm swapping out the 3 inch studs on my new Strange axles for some 2 inch ones. I need to know what if any thread lock I should put on them? Anyone know what they should be torqued to? Thanks!
1970 Duster 340 clone
Re: Thread lock on axle studs? [Re: BrianT] #814848
09/26/10 01:32 PM
09/26/10 01:32 PM
My 64 dodge shop manual shows 65 lbs for lug nuts on 1/2 x 20 OE studs. If yours are aftermarket they may require higher to get the right amt of stretch. blue loctite & I 1st hit parts w a shot of starting fluid to clean em so the Loctite will adhere better.
