Solid lifter question? #814621
09/26/10 12:40 AM
09/26/10 12:40 AM
North Dakota
440abody Offline OP
440abody  Offline OP
North Dakota
I was just sitting here looking for lifters for my 440 and I had an odd thought. Could solid lifters be used on a cam that has been ground for hydraulic lifters? If so, then what would some of the advantages or disadvantages be? Just a curious thought.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: Solid lifter question? [Re: 440abody] #814622
09/26/10 01:17 AM
09/26/10 01:17 AM
iirc a hyd lifter on a solid cam will make the solid cam (effectively) milder as some lift/duration will be lost in the transition and a hyd cam has too fast of ramp speed to use a solid lifter. Dont quote me on this just what I remember reading.
Re: Solid lifter question? [Re: RapidRobert] #814623
09/27/10 10:38 AM
09/27/10 10:38 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Actually the hyd lifter will eliminate the valve lash used with a solid lifter making the solid cam effectively larger by several degrees duration and what ever the lash was in lift. But,(and this is a big but) some lobe profiles work ok with either style lifter and others do not. Better ask the cam manufacturer about the specific lobe in question.
Re: Solid lifter question? [Re: GomangoCuda] #814624
09/27/10 11:40 AM
09/27/10 11:40 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
To make a ong story short a solid lifter cam will not work efficiently with a hyd. lifter and vice versa. If they did they would make only one type of cam - one that would be efficient either way.
