71 B-body A/C drier and low pressure cutoff switch
#814616
09/26/10 12:38 AM
09/26/10 12:38 AM
Posts: 93 Anacortes, WA
russ71satellite
Anacortes, WA
I am replacing the drier on 71 b body, stock a/c system. Auto Zone, O'reilly, Advance Auto and Napa are all selling the same drier, which has too large of a hole for the proper cutoff switch to be installed on the drier.
Each of the stores lists a cutoff switch for my car, but these switches do not fit the driers listed for the car.
Ideas??
71 Satellite Sebring, all stock 1989 Dodge Daytona, daily driver 2008 PT Cruiser
Re: 71 B-body A/C drier and low pressure cutoff switch
[Re: DynoDave]
#814618
09/26/10 10:00 AM
09/26/10 10:00 AM
russ71satellite
Anacortes, WA
thanks for the response. Yes, I did check them out, and they could solve the problem.
But, being a little slow sometimes, I figured out this morning that all I need to do is use the other port on the other side of the drier for my switch fitting.
I will just paint the brass fitting in the other side black to hide it a little.
[Re: russ71satellite]
#814619
09/26/10 11:51 AM
09/26/10 11:51 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
These guys are good too. http://www.nostalgicairparts.com/Great prices, lots of info and free shipping. I used them to get the biggest condensor that would fit in my 26" e-body radiator openning (17" by 27 1/2" including the width with the aluminum line curving up to the reciever/drier). The price was lower than anywhere else for 134a style condensor and the quality is high. I had them mount and install the reciever dryer and plumb an aluminum line to it, all for $140 something.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
